Check out the JMPĀ® Marketplace featured Capability Explorer add-in
Voizingu
[JSL] Script for Two-One Side T-Test on a large number of metrics
Hello All,
I would like to write a JSL script to automate a TOST (Two-One Side T-Test) on a large number of metrics (500+).
The TOST works by pair of ā€œlevelsā€, so working with 2x levels is easy, because it requires only 1x row per ā€œpairā€.
I already wrote a script that works well for 2x levels by generating a ā€œCombined data tableā€ and adding more columns with formula to it, which end up with the results: ā€œEquivalentā€ or ā€œNot Equivalentā€.
The problem thickens when I want to work with more than 2x Levels, it would require to find all possible unique pairs of ā€œLevelsā€ and then run the TOST math for every combination of Metric + pairs of Levels.
I found a way (on this forum) to find all possible unique pairs from a list and put them in a table or in a nested list (NchooseKmatrix()).
But I am stuck there. What I need is:
1-  to populate a new table with all possible combinations of Metrics (Column1) and all pairs of possible levels (Column2 and Column3).
2- Then add the stats for each pair of level on each row
From this point I will be able to figure out the math to finalize the TOST.
I have attached a script that generates a dummy table, then a combined data table from the Oneway analysis, then my unsuccessful attempt of creating a third table with all combinations of Metrics + Unique pairs of level
Thanks in advance for your help
clear symbols();
Deletesymbols();
//Create table with random distribution (table 1)
dt = New Table( "tabletest",
	Add Rows( 500 ),
	New Column( "Product", Character, "Nominal", formula("Product " ||char( Random Integer( 1, 4 )))),
	New Column( "Metric1", Numeric, "Continuous", formula( Random Normal( 10, 1 ) ) ),
	New Column( "Metric2", Numeric, "Continuous", formula( Random Gamma( 10, 1 ) ) ),
	New Column( "Metric3", Numeric, "Continuous", formula( Random Gamma( 10, 2 ) ) )
Column( dt, "Metric1" ) << set property( "spec limits", {LSL( 5 ), USL( 25 ), Show Limits( 0 )} );
Column( dt, "Metric2" ) << set property( "spec limits", {LSL( 0 ), USL( 40 ), Show Limits( 0 )} );
Column( dt, "Metric3" ) << set property( "spec limits", {LSL( 5 ), USL( 40 ), Show Limits( 0 )} );
dt << save( "$Desktop\tabletest.jmp" );
//Get a list from all unique Product
SplitBy = "Product";
summarize(ColumnSplitBy=by(Column (SplitBy)));
show(ColumnSplitBy);
For( i = N Items( ColumnSplitBy ), i > 0, i--,
  If( ColumnSplitBy[i] == "",
  Remove From( ColumnSplitBy, i, 1 );
//Get Column name
MetricCols = dt << Get Column Names( numeric, continuous, "string" );
//Get all unique combo of 2 Products
ColumnSplitByCombo = aslist( nchoosekMatrix(nitems(ColumnSplitBy), 2));
show (ColumnSplitByCombo);
//Create a combinaed datatable with stats (Table 2)
ow = dt << Oneway(
	Y(Eval(MetricCols)),
	X(Eval(SplitBy)),
	Means and Std Dev(1),
		Dispatch(
			{"Means and Std Deviations"},
			"Std Dev Lower 95%",
			NumberColBox,
			{Visibility("Visible")}
		Dispatch(
			"Std Dev Upper 95%",
			NumberColBox,
	Invisible
tb = Report(ow[1])[Outline Box("Means and Std Deviations"), Table Box(1)];
dt2 = tb << Make Combined Data Table;
tb << close window;
//Create new table for the result, each row has a unique pair of Levels
dt3 = astable( nchoosekMatrix(nitems(ColumnSplitBy), 2), << column names({"x", "y"}) );
dt3 << new column ("first", character, << set values ( ColumnSplitBy[dt3:x << get values]));
dt3 << new column ("second", character, << set values ( ColumnSplitBy[dt3:y << get values]));
dt3 << delete columns (1::2);
//Create a nested list with each pair of levels
Listdt3 = aslist( nchoosekMatrix(nitems(ColumnSplitBy), 2));
show (Listdt3);
// I tried to use associate array() to match the level and name but couldn't make it work
-Voiz
Re: [JSL] Script for Two-One Side T-Test on a large number of metrics
I would most likely use loops myself, but you can do it with some matrix operations. This script would require a rewrite to make it easier to read in my opinion (better named variables, utilizing Output table name, closing unnecessary tables and general cleanup)
View more...
dt = New Table("tabletest",
	Add Rows(5000),
	New Column("Product",
		Character,
		"Nominal",
		formula("Product " || Char(Random Integer(1, 4)))
	New Column("Metric1", Numeric, "Continuous", formula(Random Normal(10, 1))),
	New Column("Metric2", Numeric, "Continuous", formula(Random Gamma(10, 1))),
	New Column("Metric3", Numeric, "Continuous", formula(Random Gamma(10, 2))),
Column(dt, "Metric1") << set property("spec limits", {LSL(5), USL(25), Show Limits(0)});
Column(dt, "Metric2") << set property("spec limits", {LSL(0), USL(40), Show Limits(0)});
Column(dt, "Metric3") << set property("spec limits", {LSL(5), USL(40), Show Limits(0)});
Summarize(ColumnSplitBy = by(Column(SplitBy)));
MetricCols = dt << Get Column Names(numeric, continuous, "string");
ColumnSplitByCombo = As List(NChooseK Matrix(N Items(ColumnSplitBy), 2));
ow = dt << Oneway(
	X(Eval(SplitBy)),
		Dispatch({"Means and Std Deviations"}, "Std Dev Lower 95%", NumberColBox,
		Dispatch({"Means and Std Deviations"}, "Std Dev Upper 95%", NumberColBox,
	Invisible
tb << close window;
Listdt3 = As List(NChooseK Matrix(N Items(ColumnSplitBy), 2));
mcols = N Items(MetricCols);
l = Repeat(Listdt3, mcols);
m = J(N Items(l) / mcols, mcols)  (1::mcols);
mfinal = Sort Ascending(Shape(m, 1, N Items(l)));
dt3 = As Table(Matrix(l), <<column names({"x", "y"}));
dt3 << New Column("metric", Character, Values(MetricCols[mfinal]));
dt3 << New Column("first", character, <<set values(ColumnSplitBy[dt3:x << get values]));
dt3 << New Column("second", character, <<set values(ColumnSplitBy[dt3:y << get values]));
dt3 << New Column("R", Numeric, Ordinal, Values(1::N Items(l)));
dt4 = dt3 << Stack(
	columns(:first, :second),
	Source Label Column("Label"),
	Stacked Data Column("Data"),
	"Non-stacked columns"n(Keep(:Metric, :R))
Close(dt3, no save);
dt4 << Update(
	With(dt2),
	Match Columns(:metric = :Y, :Data = :Level)
dt_split = dt4 << Split(
	Split By(:Label),
	Split(
		:Metric, :Data, :Number, :Mean, :Std Dev, :Std Err Mean, :Lower 95%, :Upper 95%,
		:Std Dev Lower 95%, :Std Dev Upper 95%
	Output Table("untitled 19.jmp"),
	Remaining Columns(Drop All),
	Sort by Column Property
13 REPLIES 13
Voizingu
I attached a document "Untitled.png" with screenshots to (hopefully) better explain my request.
You could for example first stack your group column, update it with the results and split it again.
This example doesn't take into account that there can be multiple Metrics
// Loop over Metrics and perform these for each of them
// Concatenate results into single table
dt3 = As Table(NChooseK Matrix(N Items(ColumnSplitBy), 2), <<column names({"x", "y"}));
dt3 << new column("R", Numeric, Ordinal, Formula(Row()));
dt4 = dt3 << Stack(
	"Non-stacked columns"n(Keep(:R)),
close(dt3, no save);
// Metrics should be taken into account here OR stacked table should contain them dt4 << Update( With(dt2), Match Columns(:Data = :Level) );
or doesn't have the final split which most likely looks something like this
Voizingu
Hello Jarmo,
Stack > Update > Split is a great idea!!!
I have been able to implement it successfully, but my code is a bit dirty (a lot of For() loops, intermediate steps,...).
Instead of:
- Concatenate the table multiple times
- Then populating a column from a list of repeated metrics
I would like to become better in optimizing my code.
Is there a way to populate dt5 in a more cleaner/optimized way? (use native JMP commands maybe?)
I would love your suggestions on this
But anyway, thanks a lot for helping me on this
-Voiz
clear symbols();
Deletesymbols();
	Add Rows( 5000 ),
	New Column( "Metric3", Numeric, "Continuous", formula( Random Gamma( 10, 2 ) ) ),
//Get Column name
show(MetricCols);
ow = dt << Oneway(
	X(Eval(SplitBy)),
		Dispatch(
			NumberColBox,
		Dispatch(
			NumberColBox,
	Invisible
tb << close window;
show (Listdt3);
dt4 = dt3 << Stack(
// create final table
dt5 = New Table("final",
	New Column( "R", Character, "Nominal"),
	New Column( "Label", Character, "Nominal"),
	New Column( "Data", Character, "Nominal")
// create the Metric list to populate into dt5 metric column <-- not very clean
MetricListFinal = {};
For (k=1, k<=N items(MetricCols), k++,
	For(j=1, j<=N rows(dt4), j++,
		Insert into(MetricListFinal, MetricCols[k]);
show(MetricListFinal);
// concatenate the stacked list of unique pairs of level <-- not very clean
For(i=1, i<=N items(MetricCols), i++,
	dt5 << concatenate(data table(dt4), append to first table(1));
// populate the column with the list of metrics <-- not very clean
dt5 << New Column( "Metric", Character, "Nominal", values(MetricListFinal));
// update table from Combined stats table
dt5 << Update(
	With(dt2),
	Match Columns(:Data = :Level, :Metric = :Y )
// split table by level
dt5 << Split(
	Split By( :Label ),
	Split(
		:Upper 95%, :Std Dev Lower 95%, :Std Dev Upper 95%
	Output Table( "untitled 19.jmp" ),
	Remaining Columns( Drop All ),
View more...
	Add Rows(5000),
		Character,
		"Nominal",
ow = dt << Oneway(
	X(Eval(SplitBy)),
	Invisible
tb << close window;
dt4 = dt3 << Stack(
dt4 << Update(
	With(dt2),
	Split By(:Label),
	Split(
Voizingu
Hey Jarmo,
Thanks for your quick response.
This line is failing
Can you explain what it is intended to do?
I don't usually use Matrices, I tried to debug myself but couldn't...
Thanks for your help
For some reason it is missing
m = J(N Items(l) / mcols, mcols)  (1 :: mcols);
Purpose is to create a matrix like this
which you then convert to
using Shape.
Also go with the loops, they are generally much easier to read and understand than weird matrix "tricks".
Voizingu
Hi Jarmo,
I tested several versions of this line, adding special characters that could be lost in translation, but no...
This line doesn't work on my end (I am using JMP Pro 17)
That's OK, this optimization using Matrix is really nice to have. As you said, using loops also works so I will go with that
Thanks again for taking the time to help me (once again)!
-Voiz
I have attached the part of code which breaks in community as a screenshot
It is element-wise multiplication of matrices E Mult()
@Ryan_Gilmore JMP community is eating (: * added space here)
JSL code block:
Text:
Screenshot of while editing
Screenshot from Preview
MRB3855
Hi @Voizingu : The TOST is just checking to see if the 100(1-2alpha)% confidence interval is contained entirely within some equivalence limits; so, perhaps an adequate workaround would be to use the Fit Y by X multiple comparisons procedure to do all the combinations for you?
