JSL: How to call outlinebox on calculated string, like: Report(platform)[OutlineBox(parse("Stepwise Fit for " || yparm))]
Hello, i try to call my outlinebox report by substituting with the table variable name (character string) I want to look at.
I first tried without substitution and it worked well.
Then i did:
NamesDefaultToHere(1);
yparm = "MyResponse1";
dt = DataTable("MyDataTable");
platform = dt << Fit Model( ... , Personality("Stepwise"), ... );
wait(0) ;
TableToGet = Report(platform)[OutlineBox(parse("Stepwise Fit for " || yparm))] ... ;
Which gives:
How to tackle this ?
Re: JSL: How to call outlinebox on calculated string, like: Report(platform)[OutlineBox(parse("Stepwise Fit for " || yparm))]
Found,
The problem was upstream when calling the Y variable. After solving that one as follows it works:
platform = dt1 << Fit Model(
   /*Y( "Challenge1Sim"),*/
	Y(parse(evalinsert("\[:Name("^yparm^")]\"));),
Try removing Parse
Edit:
Simple example
dt = Open("$SAMPLE_DATA/Drug.jmp");
fit = dt << Fit Model(
	Y(:y),
	Effects(:Drug, :x),
	Personality(Standard Least Squares),
	Run Model()
ob = Report(fit)[OutlineBox("Residual by Predicted Plot")];
myvar = "Predicted Plot";
ob2 = Report(fit)[OutlineBox("Residual by " || myvar)];
show(ob, ob2, ob == ob2);
// ob3 = Report(fit)[OutlineBox(Parse("Residual by " || myvar))];
Nope, that does not work.
I also tried:
[OutlineBox(evalinsert("\[Stepwise Fit for ^yparm^]\");)]
Did also not work
Variable name has special characters, but i would not expect it to be a problem:
yparm = "Challenge1+E(N(0,1))";
Because:  Performing manually:   rmb 'Make into Data Table ' -> open script 'Make into Data Table'
Gives me entry:
Report(platform)[OutlineBox("Stepwise Fit for Challenge1+E(N(0,1))")]
And that runs.
It goes south once i try to do it dynamically.
Any other suggestions?
Found,
