bernie426
JSL: Combined graphs from multiple data table and combined into a single window
If I have graphs from multiple data table and like to combined those graph into a single window for a report, how can this work out using a script. I tried a simple script below using jmp provided tables, but the script does not work out from me. Can anyone help?
Here is my script,
New Window( "Combined graphs",
  V Sheet Box(
  <<Hold(Open( "$SAMPLE_DATA/Big Class.jmp" ),
       Bivariate(
                      Y( :weight ),
                      X( :height ),Fit Line()
  <<Hold(Open( "$SAMPLE_DATA/Big Class.jmp" ),Treemap( Categories( :age ) ) ),
       Bubble Plot(
                      X( :height ),
                      Y( :weight ),
                      Sizes( :age ),
                      Coloring( :sex ),
                      Circle Size( 6.226 ),
                      All Labels( 0 )
  <<Hold(Open("$SAMPLE_DATA/Diabetes.jmp"),
  Distribution( Continuous Distribution( Column( :BMI ) ) );
  H Sheet Box(
  Sheet Part(
  "weight by height",
  Excerpt Box(
  1,
  {Picture Box( 1 )}
  Sheet Part(
  Excerpt Box(
  3,
  {Picture Box( 1 )}
  H Sheet Box(
  Sheet Part(
  "height by weight",
  Excerpt Box(
  4,
  {Picture Box( 1 )}
  Sheet Part(
  "BMI Distribution",
  Excerpt Box(
  4,
  {Picture Box( 1 )}
pmroz
Re: JSL: Combined graphs from multiple data table and combined into a single window
Maybe something like this?
bv = expr(dt << Bivariate( Y( :weight ), X( :height ), Fit Line() ));
tm = expr(dt << Treemap( Categories( :age ) ));
bp = expr(dt << Bubble Plot( X( :height ), Y( :weight ), Sizes( :age ), Coloring( :sex ), Circle Size( 6.226 ),
                        All Labels( 0 )));
dtd = Open( "$SAMPLE_DATA/Diabetes.jmp" );
dist = expr(dtd << Distribution( Continuous Distribution( Column( :BMI ) ) ));
      lineup box(ncol(2), bv, tm, bp, dist);
ian_jmp
Level X
Something like this, perhaps? Else use 'Window > Combine Windows' and make an Application.
NamesDefaultToHere(1);
dt1 = Open("$SAMPLE_DATA/Big Class.jmp");
g1 = Expr(dt1 << Bivariate( Y( :height ), X( :weight ) ));
dt2 = Open("$SAMPLE_DATA/Bands Data.jmp");
g2 =  Expr(dt2 << Distribution( Nominal Distribution( Column( :Name( "Banding?" ) ) ) ));
win = NewWindow("Reports from Two Tables", HListBox(g1, g2));
pmroz
                        All Labels( 0 )));
gutloja
I was wondering about this myself the other day. Thanks for sharing!
-JoseL
