rct
rct
JSL + A script that extracts textbox information from a bivariate fit report
  I have a set of data on which I have performed a linear fit. I am trying to write a script that would extract the text box information which is basically the fit equation from the bivariate fit report . Any help is highly appreciated !
ms
Super User (Alumni) ms
Re: JSL + A script that extracts textbox information from a bivariate fit report
The pathway to the text edit box may vary depending on the complexity of your report. The code below works for that particular report and probably for many other simple bivariate reports. Use the tree structure display for your particular report to find out the relative (or absolute) pathway.
biv = dt << Bivariate(Y(:weight), X(:height), Fit Line());
rbiv=report(biv);
// Two equivalent ways to address the text box with the equation
eq1=rbiv[Outline Box(2)][1, 1] << get text; // "First item of the first item of the second outline box"
eq2=rbiv[Text Edit Box(4)] << get text; // Direct address. Numbering not always predictable.
show(eq1,eq2);
// Explore the tree structure to detrmine the pathway to the displaybox of interest
rbiv<<show tree structure;
ms
rbiv=report(biv);
show(eq1,eq2);
rct
rct
Thanks a ton ! It was of great help
