Seeing this in my JSL Logs recently, has jmp19 adapted to something else ? This will eventually be phased out, i have used a custom fuction to convert jmp table to pandas dataframe in jmp18 but that didn't work for jmp19. So, what are the ways to achieve the same now?
I run my python code inside the JSL Script.
Python Send(o28k_raw);
Python Submit(
raw_data = pd.api.interchange.from_dataframe(o28k_raw)
This warning:
<string>:18: Pandas4Warning: The Dataframe Interchange Protocol is deprecated.
For dataframe-agnostic code, you may want to look into:
- Arrow PyCapsule Interface: https://arrow.apache.org/docs/format/CDataInterface/PyCapsuleInterface.html
- Narwhals: https://github.com/narwhals-dev/narwhals
