jheadley
JMP15 modal window with check box behavior
OK so I have code that worked fine in JMP 14, it went like this:
ithead = "EAR Configuration for Factor Cross Plots";
itprompt = "Select to Include EAR warning on Factor Cross Plots.";
itwarn =
"WARNING – This document contains technical data classified under the Commerce Control List and assigned Export Control Classification Number (ECCN) 0A606.x and 0E606. ";
//determine if itar/ear warning is required
itwin = New Window( ithead,
	<<Modal,
	H List Box( check1 = Check Box( itprompt, ), H List Box( "" ) ),
itar = check1 << Get;
Show( itar );
I see that now basically all the instances in my code where I try to get the output of a window after it closes don't work anymore in JMP15, and you can use On Close or on Validate to get most things working.  This has worked for me with text boxes and On Close.  In this case, I tried:
itwarn =
"WARNING – This document contains technical data classified under the Commerce Control List and assigned Export Control Classification Number (ECCN) 0A606.x and 0E606.";
	<<Modal,
	<<On Validate( itar = check1 << Get ),
Show( itar );
If I use On Validate, I get the following error:
Object 'EvalContextBox' does not recognize the message 'On Validate'; perhaps you mean one of these: <<Inval Size <<Inval <<Journal <<Copy Data <<On Close <<Journal Window <<Horizontal Alignment <<Enabled.
If I use On Close and don't choose the check box - there is no way to close the modal window.  Choosing OK does nothing and the X in the corner will also not close the modal window.  If I choose the check box, it returns 1 and works correctly.  If I choose the check box and then unchoose it, the window won't close.  How do I get a 0 value to return and be able to close the window?
Jeff_Perkinson
Re: JMP15 modal window with check box behavior
Try the <<Return Result message to get a list of the results of the dialog.
	<<Modal,
	<<Return Result,
show(itwin);
Log (when check box was checked):
	<<Modal,
	<<Return Result,
show(itwin);
itwin = {check1 = {1}, Button(1)};
-Jeff
I think your best solution, is to place the action to set variable itar, in a script that is executed when the check box is selected or unselected
itwarn =
itar = .;
	<<Modal,
	H List Box( check1 = Check Box( itprompt,itar = check1 << Get ), H List Box( "" ) ),
Show( itar );
Jeff_Perkinson
	<<Modal,
	<<Return Result,
show(itwin);
	<<Modal,
	<<Return Result,
show(itwin);
-Jeff
jheadley
I didn't know about the return result option - always good to learn new tricks, thanks.
itwarn =
itar = .;
	<<Modal,
Show( itar );
jheadley
this is the approach I ended up using - most direct. thanks!
