jheadley
JMP 15 Modal Number Edit Box Quirks
OK so I have the following number edit box that worked fine in JMP14, but I can't use the <<Get after the box declaration anymore.
I tried this:
savechoice = 1;
pfp = New Window( "Save Models and Columns",
	<<Modal,
	Text Box(
		"Would you like to save the predicted formula columns and fit model? Please review them before you answer."
	Text Box( "Enter 1 for Yes, 0 for no." ),
	H List Box( Num2 = Number Edit Box( 1 ) ),
	Text Box( "" ),
	<<On Close( savechoice = Num2 << Get )
Show( savechoice );
But if I type 0 into the box to say "don't save" it won't let me close the box.  It's like 0 isn't a valid input for a number edit box.  If I type 1,2, or any other number it works fine.  What is going on?  thanks.
Re: JMP 15 Modal Number Edit Box Quirks
Here is the preferred method with a Number Edit Box.  See the Scripting Index on the Set Function message in the Number Edit function
savechoice = 1;
	<<Modal,
	Text Box(
	H List Box( Num2 = Number Edit Box( 1, 10,
		<<SetFunction(
			Function( {this}, /* put my value into my sibling's display */
				savechoice = this << getText )
	Text Box( "" )
Show( savechoice );
savechoice = 1;
	<<Modal,
	Text Box(
		<<SetFunction(
	Text Box( "" )
Show( savechoice );
jheadley
thanks. Still seems like a ton of characters for what used to be simply a Num2<<Get; that I would put after the window box. I have no idea why they changed all of this in JMP15 but it is driving a ton of work for me.
