rajang
JMP15 JSL script save presentation error
I get the following error if I have the EMF, PNG or JPG in the Save Presentation syntax. The same script works fine in JMP13; Is there any script change for JMP15.
biv = bivariate( y( :weight ), x( :height ) );
rbiv = biv << report;
rbiv << Save Presentation( "$TEMP/jmp_example.pptx", PNG );
Open( "$TEMP/jmp_example.pptx" );
Thanks
Rajan
Re: JMP15 JSL script save presentation error
If I put "PNG" in quotations it seems to work.  Please try that and see if it resolves the issue.
This is a good general practice for options that do not take any arguments.  It looks like this particular option was changed to allow variable evaluation, as in:
fmt = "PNG";
rbiv << Save Presentation( "$TEMP/jmp_example.pptx", fmt );
fmt = "PNG";
The Scripting Index does not reflect this change.  I will put in the bug notification
