Dora
JMP v19
I'm currently using JMP v18 and was wondering when v19 will be available?  My license shows that the current license expires today, 5/31/2025
Re: JMP v19
19 is probably later this year. The support team can help if your license has shut you out, menu at top of screen.
Dora
Re: JMP v19
Thanks for your reply Craige.
P_Bartell
Level VIII
Re: JMP v19
If this helps...years ago (I'm now a retired SAS employee in the JMP division) JMP was on an approximate 18 month new version release cycle. Not sure if that is still the case. Best bet would be to contact your sales team...they can give you an idea.
Ressel
Re: JMP v19
Yes, users are still being told about the 18-month version release cycle. The show must go on.
Re: JMP v19
You should be able to get JMP 19 by the end of September.
Brian Corcoran
JMP Development
JesperJohansen
Re: JMP v19
Will JMP 19 bring back SAS integration? And how will it be different from the integration in JMP 17 and earlier?
BR
Jesper
Re: JMP v19
Hi Jesper,
Yes, JMP 19 will restore SAS Integration.  There will be a few changes necessary to get JSL programs to connect.  I believe JMP 19 will actually improve on SAS Integration, as SAS Viya access will be supported and you'll be able to use CAS tables in the SAS Query Builder.  If you have access to the JMP Early Adopter program, you can try these features out now.
Brian Corcoran
JMP Development
