How to get results of anova table for two with interaction including due to columns, rows and interaction
The anova model specified gives the ANOVA table with model, error and total. how do we get the usual anova table including the sum of squares due to columns, rows and interaction in the same anova table
MRB3855
Re: How to get results of anova table for two with interaction including due to columns, rows and interaction
Hi @CriticalBias358 , and welcome. In the Fit Model output, from the red triangle menu at the top, choose "Regression Reports" then "Effect Tests".
Also, you can change the default output on any platform via File/Preferences. That way you can choose the Effect Tests (and many other things) to be displayed by default (rather than manually as I've shown above).
