I'm wondering if JMP can be used in a virtual environment? Is anyone using JMP through Citrix?
Can anyone point me to documentation?
This is the response we received from JMP Technical Support.
JMP is not licensed to be installed on server machines. The installation of JMP on server machines is possible, but not allowed. The licensing agreement does not permit JMP to be installed on a server at this time. At this time, JMP is only permitted on desktop operating systems (Win XP, Vista, 7 and 8, Mac, etc).
Our system requirements are listed here:
Hi RonF,
Maybe this documentation could help you.
http://analytics.ncsu.edu/sesug/2012/DJ-01.pdf
http://www.jmp.com/software/pdf/JMPConfigurationCitrixAppXen6.pdf
http://www.citrix.com/ready/partners/sas-institute/products/jmp
Thank-you so much gbu.
This certainly helps. I can't get to the last 2 documents, but the first document has great information.
Ron
Thanks for this official answer.
We are using JMP on Citrix. Talk to your salesperson about getting a server license. Runs good!
As @pmroz suggests...the best way to start evaluating the server deployment process for using JMP is to contact your JMP sales account executive. Lots of issues to consider before deployment...but many companies and organizations choose this method of JMP deployment for a variety of business and technical reasons.
We already have licenses in our possession. We tried to install a version on APP-V without success.
Is it possible to install and is JMP compatible with Vmware or Hyperv, in Client - Server mode.
These sorts of issues are best resolved by contacting both your JMP account executive as well as JMP technical support. The general contact portal for JMP technical support can be found here:
https://www.jmp.com/en_us/support.html
