DVLuna
Re-ordering the script list saved to a Data Table
I have created a set of scripts for a given data table and I would now like to "re-order" the scripts as they appear in the top left area of the Data Table view.
I can't seem to find anything on the forums or in the Help section to address this.
Basically the scripts are listed in the order they were created/saved.  Is there a method for sorting/adjusting the list after creation?
Thanks in advance for any assistance.
David_Burnham
Re: Re-ordering the script list saved to a Data Table
Interactively in JMP you have drag and drop the table scripts to re-order them.  YOu have to do a long-click then drag otherwise the drag movement will simply select multiple scripts.
-Dave
6 REPLIES 6
I am not aware of any simple way to reorder the Table Scripts.  However,  below is a simple script I put together that will alphabetically sort the scripts in a given data table.
dt = Open( "$SAMPLE_DATA\big class.jmp" );
// Get the list of scripts
names = dt << Get Table Script Names;
// Setup a list to sort alphabetically
namestosort = names;
Sort List Into( namestosort );
// Pull into a list all of the scripts
dt << Select Properties( names );
proplist = dt << Get Selected Properties();
// Pass through the sorted list, deleting each script and
// then resaving it
For( i = 1, i <= N Items( names ), i++,
	dt << delete Table Property( namestosort[i] );
	Eval( Parse( "dt<<" || Char( proplist[Loc( names, namestosort[i] )] ) ) );
David_Burnham
-Dave
DVLuna
David,
This is exactly what I was trying to figure out!
Perfect.
Thank you very much.
Dave
wis
wis
I don't see this working in JMP 13.2.1 (64 bit)
I am running JMP 13.2.1 on 64bit windows and it works fine for me.
wis
wis
Well, for whatever reason, it decided to work this morning.
