ronf
JMP on Citrix?
I'm wondering if JMP can be used in a virtual environment? Is anyone using JMP through Citrix?
Can anyone point me to documentation?
ronf
Re: JMP on Citrix?
This is the response we received from JMP Technical Support.
JMP is not licensed to be installed on server machines.  The installation of JMP on server machines is possible, but not allowed.  The licensing agreement does not permit JMP to be installed on a server at this time.  At this time, JMP is only permitted on desktop operating systems (Win XP, Vista, 7 and 8, Mac, etc).
Our system requirements are listed here:
    http://jmp.com/support/system_requirements_jmp.shtml
10 REPLIES 10
ronf
Re: JMP on Citrix?
Thank-you so much gbu.
This certainly helps. I can't get to the last 2 documents, but the first document has great information.
Ron
ronf
Re: JMP on Citrix?
gbu
gbu
Re: JMP on Citrix?
Thanks for this official answer.
InfoFr
Re: JMP on Citrix?
Sorry to go back to this topic, we want to install JMP Pro in client server mode, do you have a more recent documentation for citrix or another virtualization environment
Best Regard
pmroz
Re: JMP on Citrix?
We are using JMP on Citrix.  Talk to your salesperson about getting a server license.  Runs good!
Peter_Bartell
Level VIII
Re: JMP on Citrix?
As @pmroz suggests...the best way to start evaluating the server deployment process for using JMP is to contact your JMP sales account executive. Lots of issues to consider before deployment...but many companies and organizations choose this method of JMP deployment for a variety of business and technical reasons.
InfoFr
Re: JMP on Citrix?
We already have licenses in our possession. We tried to install a version on APP-V without success.
Is it possible to install and is JMP compatible with Vmware or Hyperv, in Client - Server mode.
Peter_Bartell
Level VIII
Re: JMP on Citrix?
These sorts of issues are best resolved by contacting both your JMP account executive as well as JMP technical support. The general contact portal for JMP technical support can be found here:
https://www.jmp.com/en_us/support.html
