Thierry_S
JMP > JSL > Response Screening > Populate columns from Column Selection?
Hi JMP Community,
JMP 16.1 / Windows 10 Pro
I have an apparently simple problem that I cannot resolve. In the following script (which does not work), I am attempting to pass a List of columns into the X variables from the RESPONSE SCREENING platform. Using a concatenated string variable does not work. Hence, how do I convert the Column List (scol) into a valid argument for running the RESPONSE SCREENING platform?
Names Default to Here (1);
dt = Data table ("MYTABLE");
scol = dt << Get Selected Columns;
rse = expr (dt << Response Screening(Y(:RESPONSE), X(_Xs_), PValues Table on Launch(0)));
X_string = "";
for (i = 1, i <= N Items (scol), i++,
	Insert into (X_string, scol [i]);
	if (i < N items (scol), Insert into (X_string, ","), Continue ());
show (X_string); // The column names are stripped of the preceding quotes and following n (my column names are complex and include special characters)
rsx = substitute (Name Expr (rse), Expr (_Xs_),X_string);
show (rsx);
rs = Eval (rsx); //Fails because of Bad X argument
rsr = Report (rs);
NOTES
This what the correct syntax should look like:
Response Screening(
	Y( :RESPONSE ),
	X(
		:"X1_MOLECULE A [M_ID 001]"n, :"X2_MOLECULE B [M_ID 002]"n,
		:"X3_MOLECULE A [M_ID 0056]"n
	PValues Table on Launch( 0 )
Thanks.
Best,
TS
Thierry R. Sornasse
Georg
Re: JMP > JSL > Response Screening > Populate columns from Column Selection?
Hi @Thierry_S , I think this should work:
BR, Georg
col_sel = dt << get selected columns();
dt << response screening( y( Response ), x( Eval( col_sel ) ) );
Georg
Georg
BR, Georg
Georg
Thierry_S
@Georg ,
Thanks. I knew it must be simple. Lessons learned: do not over-complicate things.
Best,
TS
Thierry R. Sornasse
