Jon_Armer
JMP file security/write-passwords
We're looking at using some of the JMP functionalities to trend/analyse data on some of our later-stage projects and our CMC group have asked if it is possible to lock the JMP files after analysis/trending to prevent unauthorised 'tampering' of the data- and I was wondering if anyone knew how to do that?
I've currently suggested just keeping the file in a password-access folder- but i'm wondering if there's anyway to add password protection to the JMP table/analysis itself?
Thanks in advance,
Jon
Jon
ian_jmp
Level X
Re: JMP file security/write-passwords
Every table can be regenerated by a script (see 'Copy Table Script' from the red triangle). Scripts can then be encrypted ('Edit > Encrypt Script...) with a 'Run' password. This could be one way to 'archive' data in a somewhat secure way, but I can think of alternatives too.
ian_jmp
Level X
