juanpamz
JMP connection to MySql Database & graphs
I have a question I can't seem to figure out.
If I connect to a database, with joins, for example with the query builder. Then I generate a dashboard with graphs.
If the database values change, will the graphs be modified automatically too? Or does JMP download the data from the database and, therefore, it will be static?
Thanks,
Juan Pablo.
pmroz
Re: JMP connection to MySql Database & graphs
JMP downloads the data from the database and is therefore static.  You will need to requery your database in order to refresh the graphs.
