JMP and Flow Cytometry Data
Does anyone use JMP to work with their Flow Cytometry data? We use FlowJo to analyze data but would like to use JMP to graph and summarize data. I have been asked to find out if others are doing this as well. Any references to papers that show the use of JMP would be helpful as well.
Thanks
Re: JMP and Flow Cytometry Data
could you give an example of the data you have and what exactly do you want to do with it?
