JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
JMP Platforms might provide different options depending on your data. Which platform are you using? What type of data are you using? My guess is you have character/categorical data and not continuous.
Numerical (and continuous) data:
Numerical (and nominal):
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '772929' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '772929') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '772929') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
