lala
Level IX
How can add a specified scale to a bar chart?
For example, using this script to add the "pla" column,
How do I add this to the horizontal scale of the bar chart?
Thanks Experts!
dt=Open("$SAMPLE_DATA/Big Class.jmp");
dt << New Column( "ran", Numeric, Continuous, Set Formula( Col Shuffle() ) );
ca="pla";New Column(ca);Column(ca)<<Formula( round(ran/40*100,0) );dt<<run formulas;Column(ca)<<deleteFormula;
p1=dt<< Graph Builder(
	Transform Column( "rows", Formula( Row() ) ),
	Size( 536, 459 ),
	Show Control Panel( 0 ),
	Variables( X( :rows ), Y( :weight ) ),
	Elements( Bar( X, Y, Legend( 5 ) ) ),
		Dispatch( {}, "400", ScaleBox,
			{Legend Model(
				5,
				Properties( 0, {Transparency( 0.5 )}, Item ID( "weight", 1 ) )
Re: How can add a specified scale to a bar chart?
Basically, all that needs to be done is to
  1. Drag Rows to the X axis
  2. Drag PLA and Weight to the Y axis
  3. Select the Bar chart Icon to change the chart to a Bar chart
  4. Right click on the graph and select
    1. Add=>Points
  5. Go to the Properties for the Bar
    1. Open the Variables paragraph
    2. Unselect PLA
  6. Go to the Properties for the Points
    2. Unselect Weight
  7. Go to the legend
    1. Right click on the PLA marker and select Marker
    2. Change the to your marker of choice
    3. Click again on the PLA marker and select Color
    4. Change the color to Red
    1. Add=>Points
    2. Unselect PLA
    2. Unselect Weight
  7. Go to the legend
lala
Level IX
Thank Jim!
Other good option is to use two bar charts. Disable Variables and pick Float as bar style for the one you wish to use for lines
