PS
PS
JMP Query builder very slow
Hi all,
I am struggling to use the query builder because it is very slow. Colleagues of mine using a different software, but with otherwise equally configured database connection, can preview a table in a split second. For me it takes 20-60 seconds with frequent freezes of the jmp sofware. Have you experienced the same problems?
I understand this is a difficult question without any further knowledge. But maybe somebody has an idea.
(JMP 14.1, 64bit system, the database is gigantic)
Thanks and regards
Re: JMP Query builder very slow
If you can't share details here, I would encourage you to write [email protected] so that you can share details with Tech Support.  There are a variety of preferences available under Preferences->Query Builder that can be tuned to help with performance, but without knowing the details of your situation (schema, filters, database) etc. it's impossible to make recommendations.
Brian Corcoran
JMP Development
Brian Corcoran
JMP Development
