Thierry_S
JMP Pro 16.1 > JSL > Col Maximum (:DATA, :BY_CAT) Returns an error: Bug or Syntax Error?
Hi JMP Community,
JMP Pro 16.1, Windows 10 Professional.
I encountered an odd behavior in a simple JSL script I am developing. In the script snippet below, the "By Var" column is not recognized as valid (see error message below). I confirmed that the simpler formula "max_y = col maximum (YCOL)" works fine. Hence, I believe that the issue is with the "By Var" portion of the formula.
For (i = 1, i <= N Items (col_ref), i++,
			YCOL = Column (dt, col_ref [i]);
			max_y = col maximum (YCOL, column (dt, "TIME_POINT"));
			show (max_y)
Am I missing a simple syntax component, or is it a bug?
Note: I cannot easily share the source data table or the complete script because of confidentiality issues.
Thanks.
TS
Thierry R. Sornasse
Thierry_S
Re: JMP Pro 16.1 > JSL > Col Maximum (:DATA, :BY_CAT) Returns an error: Bug or Syntax Error?
UPDATE:
For some reason, when using the Col Maximum with a "By Var", I needed to specify that the column is a reference to a column
max_y = col maximum (as column (YCOL), column (dt, "TIME_POINT"))
SOLVED
Thierry R. Sornasse
Thierry_S
UPDATE:
SOLVED
Thierry R. Sornasse
Level XI
Does the Col Maximum outside of a Column formula work?
alternatively, you could try
Summarize(by, Max(...))
