Jackie_
JMP 19 Dark Mode
Why doesn't dark mode apply correctly to the Window/Table component? The font turns white, making it difficult to read against the background.
Re: JMP 19 Dark Mode
Hey @Jackie_ - Two possibilities come to mind - one (something I encountered on the Mac) was that I had set something in the styles group of preferences to white or something.  The other option (that I can think of - I'm sure there are probably more) is that there is something about the windows theme that you are using that might be causing a conflict.
To address the first possibility you can go into styles and there is a button that says "original" that should reset everything.
To address the second, you might need to contact tech support ([email protected]) to get some help unraveling what might be going on.
(Edit: you might also have a look at this thread in the community - it looks like a similar problem to yours but in reverse: https://community.jmp.com/t5/Discussions/JMP19-Stuck-in-Dark-Mode/td-p/905568)
Hope that helps!
Best,
M
Hope that helps!
Best,
M
HaltsMaulwurf
Thanks @MikeD_Anderson ,
this solution works fine also for me,
But there is arising another issue with that:
When exporting a report or graph in dark mode, JMP uses a predefined gray background. I would prefer a white background for the export, but this seems to conflict with the dark mode settings. Is there a preference or setting I might have overlooked that allows customizing the export background color in dark mode?
This is how my graph is exported with the neccesary dark background color setting for correct display of menus etc in the dark mode
Try that
HaltsMaulwurf
this one works well :)
Come to the dark side, we have cookies :o)
