lloydwest7
JMP19 Stuck in Dark Mode
Since the switch to JMP19 this week, my JMP has been in dark mode, which matches my Windows set-up. I want JMP to be in light mode, but when I go into preferences, it already has "light mode" highlighted and thinks that this is what is being displayed, despite it clearly being dark mode.
I have toggled through the different themes in the preferences menu, but it remains in Dark mode. Any ideas? Sounds like it may be a bug.
Re: JMP19 Stuck in Dark Mode
Hi @lloydwest7 ,
Just to make sure, you have 'light mode' checked but do you mean you have 'light' selected under Preferences > Windows Specific > Color Mode?
If this is the case and it still isn't working, it's best to email [email protected] to get this logged.
Thanks,
Ben
Hi @lloydwest7 ,
Thanks,
Ben
lloydwest7
Ah thank you, a very easy fix.
Hadn't spotted the Windows specific option in the menu and I was trying to change it in "styles".
Ressel
I'm glad to learn I wasn't alone in being confused by this. Thanks for the fix.
I am having the same issue but I'm on MacOS so there's no "windows specific" category. Anyone know how to fix this without turning dark mode off for my whole computer?
