WoHNY
JMP 16: Add Timestamp to Excel File Name
I am exporting jmp data tables to Excel using the script below,
//Specifying Data Tables For Export to Excel
tableList = {tab1DT,tab2DT,tab3DT,tab4DT,tab5DT,tab6DT};
//Specifying the Worksheets in the Excel Workbook
sheetList = {"WS1","WS2","WS3","WS4","WS5","WS6"};
//Send to Excel FIle
Create Excel Workbook( "C:/Users/FileName.xlsx",tableList,sheetList);
Right now the Excel file name will be FileName.xlsx. I would like to add the timestamp (Format YYYYMMDDHHMM) at the beginning of the file name so for example, 202303021550 FileName.xlsx. Will the Timestamp at Start function accomplish this? Not sure how to apply.
Re: JMP 16: Add Timestamp to Excel File Name
Many different ways of doing this and which to use depends where you are getting your timestamp, your JMP version and your regional settings.
I'm not sure if JMP will recognize that format so you might have to build it by using different functions. One option is to first build it as something JMP will recognize and then use Substitute (or Regex) to remove unnecessary characters. Format Pattern only works if you have JMP16+
date_str = Format(Today(), "Format Pattern","<YYYY><-><MM><-><DD> <hh24><::><mm>");
//using regex
date_cleaned = Regex(date_str, "[^\d]", "", GLOBALREPLACE);
//using subsitute
date_cleaned = Substitute(date_str, ".", "", ":", "", "-", "", " ", "");
Quite often when I'm saving filenames with timestamp from JMP, I will just use Char(Today()) which will then be seconds from 1904-01-01 00:00:00
Create Excel Workbook( "C:/Users/" || date || "FileName.xlsx",tableList,sheetList);
 The  || operator allows you to concatenate strings.
//using regex
//using subsitute
WoHNY
Jarmo: Thank you for the response. If I go with Char(Today()) how do I reference it in the path/file name? Whatever I place prior to FileName.xlsx in the path/name string below will just add as is to the FileName. Define
date = Char(Today()) but then how do I get this incorporated into the file name? is there a special character that will reference it?
WoHNY
Jim:
Thank you for the input.
Greg
