Onjai
JMP 15 date time format changes
I upgraded to JMP15 recently and found that some of my scripts written in JMP14 did not work properly.  I found that this line did not work because of an unrecognized format:
New Column( "Date", Numeric, "Continuous", Format( "d/m/y h:m:s", 22, 0 ), Input Format( "d/m/y h:m:s", 0 ) ),
When I changed it to read:
New Column( "Date", Numeric, "Continuous", Format( "d-m-y h:m:s", 22, 0 ), Input Format( "d-m-y h:m:s", 0 ) ),
It worked.
I see that the "/" is not available as a separator in JMP 15.  Is this the new norm?  Why did SAS decide to change this?
Is there another way to format the "/" back into the string?
Thank you
Cheers
Re: JMP 15 date time format changes
There seems to be a format specification mismatch.  You are specifying to use
Format( "y/m/d h:m:s", 22, 0 ),
	Input Format( "y/m/d h:m:s", 0 )
in your script, however, your data are not in that format
Date
22/10/2019 6:15:00 AM
22/10/2019 6:16:00 AM
22/10/2019 6:17:00 AM
22/10/2019 6:18:00 AM
22/10/2019 6:19:00 AM
The JSL will work if you change the Format and Informat to:
I have not been able to replicate your findings. Can you please specify what operating system you are using?
Like @txnelson I was unable to reproduce this problem. Here is my attempt:
Screen Shot 2019-12-21 at 8.00.01 AM.pngScreen Shot 2019-12-21 at 8.00.01 AM.png
This picture shows the Log. The format specified with forward slashes still works.
Screen Shot 2019-12-21 at 8.00.23 AM.pngScreen Shot 2019-12-21 at 8.00.23 AM.png
The data table show that the column format specified the same way also works.
Onjai
I am using JMP 15 and O/S is Win 10 Pro - 64 bit.
Attaching a csv file and the JSL script.  I still receive the error when using the "/" placeholder.
Hope this helps.
Thank you.
Cheers
Date
Onjai
Thank you Jim.
Still, it seems odd that the script works in JMP 14 with
y/m/d
I will continue as suggested.
Thank you and the JMP community for all of your help.
Cheers!
SteveTerry
Hi @Onjai, I encountered a similar problem with Input Format (along with Format) and tracked it down to a System Preferences setting.  This wouldn't likely address the y/m/d vs d/m/y issue flagged by @txnelson, but may help you understand the dashes vs slashes behavior.
Onjai
Thank you Steve.  Always nice to have more follow through on some of these.
Cheers.
