vince_faller
JMP 14.1 process screening
In the 14.1 release notes it says.
In the summary reports in Process Screening and Process Capability, the following values are color coded: Stability Index, Ppk, Cpk, Cp, and Target Index. Green, yellow, and red indicate adequate, marginal, and poor stability or capability. Output for the Save Summary Table option in Process Screening is also color coded. The color coding can be customized or removed.
I've tried finding how to change color coding or remove it, and can't find it.  Also, it definitely isn't color coding on the Save Summary Table.
Vince Faller - Predictum
gzmorgan0
Re: JMP 14.1 process screening
It appears the color coding is for reports. See Preferences > Reports > Show Conditional Formatting.
The menu item allows Never amd Manage Rules allow you to modify the color settings and to create custom rules.
gzmorgan0
Color coding of the summary table will be available in a future version of JMP.  As the previous user suggested, you can use preferences to alter the color coding.
Jeff_Perkinson
The Process Screening summary statistics are colored in JMP 14.1. In the screen capture below JMP 14.0 is on the left and 14.1 is on the right.
JMP 14.0 on the left and 14.1 on the rightJMP 14.0 on the left and 14.1 on the right
As @gzmorgan0 said, you can customize these colors in the Reports section of Preferences using the Manage Rules button.
Preferences->Reports->Manage RulesPreferences->Reports->Manage Rules
As @tonya_mauldin0 pointed out, it looks like we jumped the gun and documented a planned feature of exporting these colors to the Save Summary table. We'll get the JMP 14.1 release notes updated to remove this.
-Jeff
Article Labels
