zetunedav
Is there a way to iterate an If statement on the last row of a table?
we have a  table that is created from a db query.  We use the date/time stamps in this table to determine start/stop times for more detailed queries.  The problem we are having is that sometimes the date/time stamps at the end of the table are not a 'matched' set.  In this table, we have created formula columns that help us identify which dates are on which row.  We know the pattern that we need to have:  the last two rows in X_3 need to end in 1 then 0.
If(dt:X_3[NRow(dt)-1] == 0, dt<< deleteRows(NRow(dt)));
If(dt:X_3[NRow(dt)] == 1, dt<< deleteRows(NRow(dt)));
Is there a way to iterate only on the last row until the table has the desired structure?
David Zetune
zetunedav
Re: Is there a way to iterate an If statement on the last row of a table?
In the end, what I needed looked like this
While( continue,
	If( dt:X_3[N Row( dt ) - 1] == 0,
		dt << deleteRows( N Row( dt ) ),
		continue = 0
Thanks
David Zetune
cwillden
I would be careful deleting rows from within a formula column.  Every time the formula is re-evaluated, it will chop off the last row.  However you can create a logical condition for the last row in a column formula using something like this:
If( Row() == N Row(Current Data Table()), do this, do that);
For your situation, I would run a separate script, not as in a formula column, to cut off the last row so you don't leave that code as a permanent feature of your resulting data table.  In that case, the script would pretty much look like what you have.
-- Cameron Willden
zetunedav
@cwillden Thanks for the input.  I'm more interested in the second option.  However, the number of rows that need to be trimmed off the bottom varies.  I was hoping I could evaluate the last row, delete it and re-valuate the If statement on the 'new' last row in a loop until the Else becomes true.
David Zetune
cwillden
Just to close the loop on this post for now, @zetunedav realized we actually work for the same company (and know each other ), so we're going to resolve this in a meeting.
-- Cameron Willden
zetunedav
While( continue,
		continue = 0
Thanks
David Zetune
