  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
TCM
TCM
Is there a way to change the order of factors in Prediction Profiler to reflect order of significance?
I use JMP Pro 16.1.
I have about 30 variables that I use to create models for subsets of people.  When I have to communicate results, I have to scroll across the page to highlight the significant factors for each specific model.  To reduce cognitive burden, it would be nice to be able to order Prediction Profiler and the Maximize Desirability answers such that significant factors are seen first.  Can this be done?
Thank you in advance for guidance.
Georg
Re: Is there a way to change the order of factors in Prediction Profiler to reflect order of significance?
You can both drag the x-variable from one to the other, or use the red triangle menu of prediction profiler -->Appearance --> Reorder X Variables.
Georg
Georg
Georg
TCM
TCM
Found it! Thank you.
