SDF1
Is there a shortcut to collapse all Expr() in JSL code?
Hi All,
  I have a JSL code with many Expr() defined and was hoping to find out if there is some shortcut keyboard command, mouse click, or menu option in JMP that allows you to collapse all within the code.
  If not, this could be a nice thing to add in future versions.
Thanks!,
DS
SDF1
Re: Is there a shortcut to collapse all Expr() in JSL code?
Hi @Mark_Bailey ,
  I actually just found out there is such a action -- a collapse all action. If you right click the editor, go to Advanced and then you can choose to expand or collapse all. By the way, I already had Code Folding enabled.
Thanks!,
DS
You might use 'code folding' in the Script Editor. Enable it in File > Preferences (Windows) or JMP > Preferences (macOS).
See the Help > Scripting Guide for more details.
SDF1
Hi @Mark_Bailey ,
Thanks!,
DS
