hi @xiaoyaj0,
You won't get skewness and kurtosis from Column Viewer, but you can actually do essentially the same thing I suggested for the Column Viewer in Distribution (I should have pointed this out in my first reply, lol). Right click in the summary statistics table and select "Make Combined Data Table". You will get a table with summary statistics for each column you have plotted in Distribution. At first, it will be in a long format like the screenshot below:
It's probably better to have this in a wide format, so I would recommend splitting Column 2, split by Column 1, and grouped by Y.
Your final table will look something like this:
-- Cameron Willden
