marcax
Is there a correlation coefficient for multiple linear regression ?
while I can display in simple linear regression a Pearson correlation coefficient to a specific R2/R2adjusted, can I, or is there a way to get a correlation coefficient for a multiple linear regression model, where two or more variables improve my R2adjusted significantly ? Many thanks, Marc
Elvic_OngGX
Staff (Retired)
Re: Is there a correlation coefficient for multiple linear regression ?
Hi Marc,
While we study on multiples input variables with output, we may get the correlations coefficients as per the menu path below:
Hope this help to answer your question.
Marc,
I am not positive that @Elvic_OngGX answered what you were asking.  My interpretation of your question, is that you want a single "r" value as in a Pearson correlation, that represents a Multiple Linear Regression.  If my interpretation is correct, the answer is your R Square or adjusted R Square is that value.  It represents the amount of relationship accounted for in your regression.  Contrary to the "r" in Peason, where the positive or negative sign denotes the direction of the relationship, the squared "R" value of a Multiple Linear Regression may have both positive and negative terms in the equasion(see the beta coefficients), therefore, the squared "R" is your representation of the correlation.
marcax
Thank you @Elvic_OngGX and @txnelson for helping me out here.
Yes, indeed @txnelson, I was trying to look for a "single" Pearson correlation coefficient for multiple linear regression. I was hoping to make a multiple linear regression analysis "easier" to understand for medical people like me, as I have a number of simple linear regression models with R2adj and Pearson correlation coefficient (Pearson always > R2adjusted) and the term correlation "appeals" more for readers than proportion of variance.
Many thanks to both of you ! Marc
