CYLiaw
Is it possible to use a custom equation to fit the data in graph builder?
Hi!
I've used graph builder to plot the data with grouped X (as shown in the attached image).  I wanted to fit all three curves using an exponential growth function. I only found Line of Fit and Smoother functions, but these are not what I would like to do.  I was wondering if it is possible to customize the fitting equation and also display the confidence interval of the fit as well as the statistics of the fit (e.g. R^2, F-test, equation) in the graph?
Thanks!
11 REPLIES 11
Re: Is it possible to use a custom equation to fit the data in graph builder?
If you are creating the graph using JSL, it is a simple modification to delete the Axis Box() associated with the right hand axis.
Can you share the script that creates the graph?
JohnMarkham
Thanks. After some fiddling, I realized that de selecting the labels box in the axis setting did the trick as well.  Here is my graph and script
Graph Builder(
    Show Legend( 0 ),
    Show Title( 0 ),
    Variables(
        X( :Name( "May-August precip" ) ),
        Y( :Name( "Ndfa (%)" ) ),
        Y( :Exponential 3P, Position( 1 ), Side( "Right" ) ),
        Overlay( :Site )
    Elements( Points( X, Y( 1 ), Legend( 13 ) ), Formula( X, Y( 2 ), Legend( 12 ) ) ),
        Dispatch(
            "Exponential 3P",
            ScaleBox,
            {Min( 60 ), Max( 105 ), Inc( 10 ), Minor Ticks( 0 ), Label Row(
                {Automatic Font Size( 0 ), Automatic Tick Marks( 0 ), Show Major Labels( 0 ), Show Major Ticks( 0 ), Show Minor Ticks( 0 )}
        Dispatch( {}, "", GraphBuilderComponentBox( 7 ), {Select} ),
        Dispatch( {}, "", AxisBox, {Select} ),
        Dispatch( {}, "", AxisBox( 2 ), {Select} ),
        Dispatch( {}, "Y r title", TextEditBox, {Set Text( "" )} ),
        Dispatch( {}, "Graph Builder", FrameBox, {Select} )
