N_Faust-BC
JMP 15 - Distribution Tool: automatically calculate the tolerance interval on start
Dear JMP Community,
My team and I switched to JMP 15 a few days ago. We use the distribution tool to assess Process Performance. In the preference menu there is the possibility to check many boxes to customize your analysis (saving us a lot of clicks, thx for that). The only problem is that I checked the boxes for tolerance interval and set my values for confidence level and proportion and this is the only "function" that is not automatically calculated when I start the analysis via the Distribution tool, so we use the red triangle to enable it manually, once the analysis window has opened. Is this intentional? I find it odd, that you can pre-select it in the preference menu, only to find it missing in the distribution analysis.
I used the profile manager to create a duplicate of my preferences (see attachment) + here is a screenshot of my preferences for tolerance interval.
Try(
	Set Platform Preferences(
		Attribute Chart(
			Attribute Gauge Charts( 1 ),
			Show Agreement Points( 1 ),
			Connect Agreement Points( 1 ),
			Agreement by Rater Confid Intervals( 1 ),
			Show Agreement Group Means( 0 ),
			Show Agreement Grand Mean( 1 ),
			Show Effectiveness Points( 0 ),
			Connect Effectiveness Points( 0 ),
			Effectiveness by Rater Confid Intervals( 0 ),
			Effectiveness Report( 1 ),
			Automatic Recalc( 0 ),
			Report View( "Full", <<Off )
		Bivariate(
			Show Points( 1 ),
			Histogram Borders( 0 ),
			Summary Statistics( 0 ),
			Fit Mean( 0 ),
			Fit Line( 0 ),
			Fit Polynomial( "2,quadratic", <<Off ),
			Fit Spline( "1000000, stiff", <<Off ),
			Kernel Smoother( 0 ),
			Fit Each Value( 0 ),
			Fit Orthogonal( "Univariate Variances, Prin Comp", <<Off ),
			Fit Robust( 0 ),
			Fit Cauchy( 0 ),
			Density Ellipse( "0.99", <<Off ),
			Nonpar Density( 0 ),
			Group By( 0 ),
		Bivariate Curve(
			Line of Fit( 1 ),
			Confid Curves Fit( 0 ),
			Confid Curves Indiv( 0 ),
			Line Color( 0, <<Off ),
			Line Style( "Solid", <<Off ),
			Line Width( "1", <<Off ),
			Report( 1 ),
			Save Studentized Residuals( 0 ),
			Mean Confidence Limit Formula( 0 ),
			Indiv Confidence Limit Formula( 0 ),
			Plot Residuals( 0 ),
			Set α Level( "0.10", <<Off ),
			Confid Shaded Fit( 0 ),
			Confid Shaded Indiv( 0 )
		Bivariate Nonpar Density(
			Kernel Control( 0 ),
			Name( "5% Contours" )(1),
			Contour Lines( 1 ),
			Contour Fill( 0 ),
			Color Theme( "Green to Black to Red", <<Off ),
			Select Points by Density( 0 ),
			Color By Density Quantile( 0 ),
			Save Density Quantile( 0 ),
			Mesh Plot( 0 ),
			Modal Clustering( 0 ),
			Save Density Grid( 0 ),
			Report( 1 )
		Bivariate Normal Ellipse(
			Line of Fit( 1 ),
			Report( 1 ),
			Shaded Contour( 0 ),
			Select Points Inside( 0 ),
			Select Points Outside( 0 )
		Bubble Plot(
			Draw( "Filled", <<Off ),
			Set Shape( "Circle", <<Off ),
			Orient Shapes( 0 ),
			Trail Bubbles( "None", <<Off ),
			Trail Lines( "None", <<Off ),
			Label( "None", <<Off ),
			Legend( 1 ),
			Selectable Across Gaps( 0 ),
			Show Roles( 0 ),
			Show Time Annotation( 1 ),
			Lock Scales( 1 ),
			Fit to Window( "Auto", <<Off ),
			X as Sum( 0 ),
			Y as Sum( 0 ),
			Size as Sum( 1 ),
			Color as Sum( 0 ),
			Name( "Save for Adobe Flash platform (.SWF)" )(0),
			Circle Size( 0, <<Off ),
			Bubble Size( 0, <<Off ),
			Speed( 0, <<Off ),
		Capability(
			Goal Plot( 1 ),
			Normalized Box Plots( 0 ),
			Capability Box Plots( 1 ),
			Capability Indices Report( 0 ),
			Individual Detail Reports( 0 ),
			Order By( "Initial Order", <<Off ),
			CPK( 1, <<Off ),
			PpK Capability Labeling( 1 ),
			Ignore columns with no spec limits( 0 ),
			Save Spec Limits as Column Properties( 0 ),
			Save Spec Limits in New Table( 0 ),
			Name( "Save Spec Limits in New Table - Tall" )(0),
		Categorical(
			Dialog Tab Default( "Simple", <<Off ),
			Use short names in dialog( 0 ),
			Frequencies( 1 ),
			Share Of Responses( 1 ),
			Rate Per Case( 1 ),
			Rate per Case Responding( 0 ),
			Share Chart( 1 ),
			Frequency Chart( 0 ),
			Transposed Freq Chart( 0 ),
			Crosstab( 1 ),
			Crosstab Transposed( 0 ),
			Count Test( 0 ),
			Homogeneity Test( 0 ),
			Exclude Nonresponses( 0 ),
			Test Response Homogeneity( 0 ),
			Cell Chisq( 0 ),
			Compare Each Sample( 0 ),
			Compare Each Cell( 0 ),
			Relative Risk( 0 ),
			Conditional Association( 0 ),
			ChiSquare Test Choices( "Both LR and Pearson", <<Off ),
			Show Warnings( 0 ),
			Order by Significance( 0 ),
			Uppercase Alpha Level( 0.05, <<Off ),
			Lowercase Alpha Level( 0.1, <<Off ),
			Base count minimum( 30, <<Off ),
			Base count warning( 100, <<Off ),
			Compare Each Cell Test( "Fisher's Exact Test", <<Off ),
			Agreement Statistic( 1 ),
			Transition Report( 1 ),
			Total Responses( 1 ),
			Response Levels( 1 ),
			Show Supercategories( 1 ),
			Total Cases( 1 ),
			Total Cases Responding( 1 ),
			Mean Score( 0 ),
			Mean Score Comparisons( 0 ),
			Std Dev Score( 0 ),
			Order by Mean Score( 0 ),
			Filter( 0 ),
			Contents Summary( 0 ),
			Show Columns Used in Report( 0 ),
			Means Decimals( 0, <<Off ),
			Grouping Option( "Combinations", <<Off ),
			Unique Occurrences within ID( 0 ),
			Count Missing Responses( 0 ),
			Order Response Levels High to Low( 0 ),
			Shorten Labels( 0 ),
			Include Responses Not in Data( 0 ),
			Include Response Categories in Excluded Rows( 0 ),
			Force Crosstab Shading( 1 ),
		Cell Plot( Legend( 0 ), Arrange Plots( 0, <<Off ), Scale Uniformly( 0 ), Center at zero( 0 ), Report View( "Full", <<Off ) ),
		Chart(
			Overlay( 1 ),
			Vertical Chart( 1 ),
			Horizontal Chart( 0 ),
			Pie Chart( 0 ),
			Add Error Bars to Mean( 0 ),
			Range Chart( 0 ),
			Stack Bars( 0 ),
			Bar Chart( 1 ),
			Line Chart( 0 ),
			Needle Chart( 0 ),
			Point Chart( 0 ),
			Show Points( 1 ),
			Connect Points( 1 ),
			Show Error Bars( 0 ),
			Overlay Color( 0, <<Off ),
			Overlay Marker( "Dot", <<Off ),
			Pen Style( "Solid", <<Off ),
			Label Format( 0 ),
			Colors( 0, <<Off ),
			Markers( "Dot", <<Off ),
			Show Labels( 0 ),
			Remove Labels( 0 ),
			Label by Value( 1 ),
			Label by Percent of Total Values( 0 ),
			Label by Row( 0 ),
			Thick Connecting Line( 1 ),
			Show Y Legend( 1 ),
			Show Level Legend( 1 ),
			Show Separate Axes( 0 ),
			Ungroup Charts( 0 ),
			Automatic Recalc( 1 ),
			Report View( "Full", <<Off ),
			Use Graph Builder( 1 )
		Choice(
			One Table( 0 ),
			Name( "Firth Bias-Adjusted Estimates" )(1),
			Respondents Are Allowed to Choose None( 0 ),
			Likelihood Ratio Tests( 0 ),
			Show MLE Parameter Estimates( 0 ),
			Joint Factor Tests( 0 ),
			Confidence Intervals( 0 ),
			Confidence Limits( 0 ),
			Correlation of Estimates( 0 ),
			Effect Marginals( 0 ),
			Utility Profiler( 0 ),
			Probability Profiler( 0 ),
			Multiple Choice Profiler( 0 ),
			Comparisons( 0 ),
			Willingness to Pay( 0 ),
			Save Gradients by Subject( 0 ),
		Cluster Variables(
			Color Map on Correlations( 1 ),
			Cluster Summary( 1 ),
			Cluster Members( 1 ),
			Cluster Components( 1 ),
			Save Cluster Components( 0 ),
			Launch Fit Model( 0 )
		Competing Cause(
			Tabbed Report( 0 ),
			Tabbed Report for Individual Causes( 0 ),
			Show Points( 1 ),
			Show Remaining Life Distribution( 0 ),
			Show Markers for Right Censored Observations( 0 ),
			Allow failure mode to use TH distributions( 0 ),
			Allow failure mode to use ZI distributions( 0 ),
			Allow failure mode to use DS distributions( 0 ),
			Allow failure mode to use fixed parameter models( 0 ),
			Allow failure mode to use Bayesian models( 0 ),
		Contingency(
			Mosaic Plot( 1 ),
			Contingency Table( 1 ),
			Tests( 1 ),
			Analysis of Means for Proportions( 0 ),
			Correspondence Analysis( 0 ),
			Agreement Statistic( 0 ),
			Relative Risk( 0 ),
			Risk Difference( 0 ),
			Odds Ratio( 0 ),
			Two Sample Test for Proportions( 0 ),
			Measures of Association( 0 ),
			Cochran Armitage Trend Test( 0 ),
			Horizontal Mosaic( 0 ),
			Make Into Data Table( 0 ),
			Name( "3D Chart" )(0),
			Count( 1 ),
			Total %( 1 ),
			Col %( 1 ),
			Row %( 1 ),
			Expected( 0 ),
			Deviation( 0 ),
			Cell Chi Square( 0 ),
			Col Cum( 0 ),
			Col Cum %( 0 ),
			Row Cum( 0 ),
			Row Cum %( 0 )
		Contour Plot(
			Show Data Points( 0, <<Off ),
			Show Missing Data Points( 0 ),
			Show Contours( 1 ),
			Show Boundary( 1 ),
			Show Control Panel( 0 ),
			Transform( "None", <<Off ),
			Fill Areas( 0, <<Off ),
			Label Contours( 0, <<Off ),
			Reverse Colors( 0 ),
		Contour Profiler Graph(
			Prediction Profiler( 0 ),
			Save Expanded Formulas( 0 ),
			Expand Intermediate Formulas( 0 ),
			Grid Density( "10 x 10", <<Off ),
			Graph Updating( "Per Mouse Move", <<Off ),
			Surface Plot( 0 ),
			Contour Label( 1 ),
			Conditional Predictions( 0 ),
			Simulator( 0 ),
			Up Dots( 1 ),
			Set Contours to Current( 0 ),
			Arrange X Controls Left( 0 ),
			Hide X Controls( 0 ),
			Hide Y Controls( 0 ),
			Multiple Contour Frames( 0 ),
			Number of Plots Across( 0, <<Off ),
		Control Chart(
			Show Limits Legend( 1 ),
			Connect Through Missing( 1 ),
			Capability( 1 ),
			Save Sigma( 0 ),
			Save Limits( "in Column", <<Off ),
			Save Summaries( 0 ),
			Box Plots( 0 ),
			Needle( 0 ),
			Connect Points( 0 ),
			Show Points( 1 ),
			Connect Color( 0, <<Off ),
			Center Line Color( 0, <<Off ),
			Limits Color( 0, <<Off ),
			Line Width( 0, <<Off ),
			Point Marker( "Dot", <<Off ),
			Show Center Line( 1 ),
			Show Control Limits( 1 ),
			Limits Precision( 0, <<Off ),
			Test 1( 0 ),
			Test 2( 0 ),
			Test 3( 0 ),
			Test 4( 0 ),
			Test 5( 0 ),
			Test 6( 0 ),
			Test 7( 0 ),
			Test 8( 0 ),
			Rule 1 2S( 0 ),
			Rule 1 3S( 0 ),
			Rule 2 2S( 0 ),
			Rule R 4S( 0 ),
			Rule 4 1S( 0 ),
			Rule 10 X( 0 ),
			Test Beyond Limits( 0 ),
			Show Zones( 1 ),
			Shade Zones( 0 ),
			Use Excluded Points on MR( 0 ),
			Report View( "Full", <<On )
		Control Chart Builder(
			Show Control Panel( 1 ),
			Show Limit Summaries( 1 ),
			Show Alarm Report( 0 ),
			Show Capability( 0 ),
			Show Sigma Report( 0 ),
			Show Excluded Region( 1 ),
			Include Missing Categories( 1 ),
			Show Two Shewhart Charts( 1 ),
			Use Event Chooser( 1 ),
			Show Lower Control Limit( 1 ),
			Stability Assessment Type( "Stability Index", <<Off ),
			Dispersion Chart( "Moving Range", <<Off ),
			Summarized Dispersion Chart( "Range", <<Off ),
			Custom Test 1( 3, <<Off ),
			Custom Test 2( 9, <<Off ),
			Custom Test 3( 6, <<Off ),
			Custom Test 4( 14, <<Off ),
			Custom Test 5( 2, <<Off ),
			Custom Test 6( 4, <<Off ),
			Custom Test 7( 15, <<Off ),
			Custom Test 8( 8, <<Off ),
		Cumulative Damage( Report View( "Full", <<Off ) ),
		Custom Profiler Graph(
			Log Iterations( 0 ),
			Simulator( 0 ),
		CUSUM(
			Show Points( 1 ),
			Mask Color( 0, <<Off ),
			Show Shift( 1 ),
			Show V Mask( 1 ),
			Show Parameters( 0 ),
			Show ARL( 0 )
		CUSUM Control Chart(
			Show Limits( 1 ),
			Show Shift Lines( 1 ),
			Show ARL( 0 ),
			ARL Profiler( 0 ),
			Control Panel( 1 ),
			Parameters Report( 0 ),
			Use Process Mean for Center Line( 0 ),
			H( 0, <<Off ),
			K( 0, <<Off ),
			Upper Side( 1 ),
			Lower Side( 1 ),
			Data Units( 0 ),
		Degradation(
			Application( "Repeated Measures Degradation", <<Off ),
			Censor Code( "1", <<Off ),
			Mean Path( 0 ),
			Location Parameter Path( 0 ),
			Median Path( 0 ),
			Simple Linear Path( 0 ),
			Custom Linear Path( 0 ),
			Nonlinear Path( 0 ),
			Connect Data Markers( 1 ),
			Show Fitted Lines( 0 ),
			Show Spec Limits( 0 ),
			Show Residual Plot( 1 ),
			Show Inverse Prediction Plot( 1 ),
			Show Curve Interval( "No Interval", <<Off ),
			Show Median Curves( 0 ),
			Show Legend( 0 ),
			No Tab List( 0 ),
			Upper Spec Limit( 0, <<Off ),
			Set Baseline( 0, <<Off ),
			Inverse Prediction Interval( "No Interval", <<Off ),
			Use Interpolation through Data( 0 ),
			Inverse Prediction Side( "Two sided", <<Off ),
			Longitudinal Prediction Interval( "No Interval", <<Off ),
			Use Interactive Formula Editor( 0 ),
		Destructive Degradation( Automatic Recalc( 0 ), Report View( "Full", <<Off ) ),
		Diagram( Report View( "Full", <<Off ) ),
		Discriminant(
			Stepwise Variable Selection( 0 ),
			Discriminant Method( "Linear, Common Covariance", <<Off ),
			Discriminant Scores( 1 ),
			Show Interesting Rows Only( 0 ),
			Show Classification Counts( 0, <<Off ),
			Show Distances to Each Group( 0 ),
			Show Probabilities to Each Group( 0 ),
			ROC Curve( 0 ),
			Select Misclassified Rows( 0 ),
			Select Uncertain Rows( 0 ),
			Use Matrix Columns( 0 ),
			Canonical Plot( 1 ),
			Show Points( 1 ),
			Show Means CL Ellipses( 1 ),
			Show Normal 50% Contours( 1 ),
			Show Biplot Rays( 1 ),
			Biplot Ray Position( 0 ),
			Color Points( 0 ),
			Show Canonical Details( 0 ),
			Show Canonical Structure( 0 ),
			Shrink Covariances( 0 ),
			Uncentered Canonical( 0 ),
			Use Pseudoinverses( 1 ),
			Cross Validate by Excluded Rows( 0 ),
			Canonical 3D Plot( 0 ),
			Specify Priors( "Equal Probabilities", <<Off ),
			Consider New Levels( 0 ),
			Show Within Covariances( 0 ),
			Show Group Means( 0 ),
			Scatterplot Matrix( 0 ),
		Distribution(
			Uniform Scaling( 0 ),
			Stack( 0 ),
			Arrange in Rows( 0, <<Off ),
			Quantiles( 1 ),
			Set Quantile Increment( 0.25, <<On ),
			Summary Statistics( 1 ),
			Horizontal Layout( 0 ),
			Axes on Left( 0 ),
			Histogram( 1 ),
			Shadowgram( 0 ),
			Vertical( 1 ),
			Std Error Bars( 0 ),
			Set Bin Width( 0, <<Off ),
			Histogram Color( -12241594, <<Off ),
			Count Axis( 0 ),
			Prob Axis( 0 ),
			Density Axis( 0 ),
			Show Percents( 0 ),
			Show Counts( 0 ),
			Normal Quantile Plot( 1 ),
			Outlier Box Plot( 1 ),
			Quantile Box Plot( 0 ),
			Outlier Box Plot Row Cutoff( 100000, <<Off ),
			Stem and Leaf( 0 ),
			CDF Plot( 0 ),
			Test Mean( 0, <<Off ),
			Test Std Dev( 0, <<Off ),
			Confidence Interval( "0.90", <<Off ),
			Normal( 1 ),
			LogNormal( 0 ),
			Weibull( 0 ),
			Weibull with Threshold( 0 ),
			Extreme Value( 0 ),
			Exponential( 0 ),
			Gamma( 0 ),
			Beta( 0 ),
			Smooth Curve( 0 ),
			SHASH( 0 ),
			Johnson Su( 0 ),
			Johnson Sb( 0 ),
			Johnson Sl( 0 ),
			GLog( 0 ),
			All( 0 ),
			Poisson( 0 ),
			GammaPoisson( 0 ),
			Binomial( 0 ),
			Beta Binomial( 0 ),
			Tolerance Interval Confidence Level( 0.95, <<On ),
			Tolerance Interval Proportion( 0.99, <<On ),
			Tolerance Interval Type( "Two-sided", <<Off ),
			Tolerance Interval Method( "Parametric Normal", <<Off ),
			Switch to Percentile Method if ZScore Method Fails( 1 ),
			Within Subgroup Variation( "Average of Unbiased Standard Deviations", <<Off ),
			Moving Range Method( "Average of Moving Ranges", <<Off ),
			Johnson Distribution Fit Method( "Quantile Matching", <<Off ),
			Nonnormal Capability Method( "Percentiles", <<Off ),
			Distribution Comparison Criterion( "AICc", <<Off ),
			Show Outlier Box Plot Shortest Half( 1 ),
			Show Box Plot Confidence Diamond( 1 ),
			Fit Normal( 0 ),
			Fit Cauchy( 0 ),
			Fit SHASH( 0 ),
			Fit Exponential( 0 ),
			Fit Gamma( 0 ),
			Fit Lognormal( 0 ),
			Fit Weibull( 0 ),
			Fit Normal 2 Mixture( 0 ),
			Fit Normal 3 Mixture( 0 ),
			Fit Smooth Curve( 0 ),
			Fit Johnson( 0 ),
			Fit Beta( 0 ),
			Fit All( 0 ),
			Fit Poisson( 0 ),
			Fit Negative Binomial( 0 ),
			Fit ZI Poisson( 0 ),
			Fit ZI Negative Binomial( 0 ),
			Fit Binomial( 0 ),
			Fit Beta Binomial( 0 ),
			Frequencies( 1 ),
			Separate Bars( 0 ),
			Mosaic Plot( 0 ),
			Order By( "Default", <<Off ),
			Use selectable frequency table for categorical data( 1 ),
			Histograms Only( 0 ),
			Create Process Capability( 1 ),
			Use Legacy Capability( 1 )
		Distribution Fit( Density Curve( 1 ), QQ Plot( 1 ), PP Plot( 0 ), Distribution Profiler( 0 ), Quantile Profiler( 0 ), Goodness of Fit( 0 ) ),
		Distribution Summary Statistics(
			Mean( 1 ),
			Std Dev( 1 ),
			Std Err Mean( 1 ),
			Upper Mean Confidence Interval( 1 ),
			Lower Mean Confidence Interval( 1 ),
			N( 1 ),
			Sum Wgt( 0 ),
			Sum( 0 ),
			Variance( 0 ),
			Skewness( 0 ),
			Kurtosis( 0 ),
			CV( 0 ),
			N Missing( 0 ),
			N Zero( 0 ),
			N Unique( 0 ),
			Uncorrected SS( 0 ),
			Corrected SS( 0 ),
			Autocorrelation( 0 ),
			Minimum( 1 ),
			Maximum( 1 ),
			Median( 1 ),
			Mode( 0 ),
			Trimmed Mean( 0 ),
			Geometric Mean( 0 ),
			Range( 0 ),
			Interquartile Range( 0 ),
			Median Absolute Deviation( 0 ),
			Proportion Zero( 0 ),
			Proportion Nonzero( 0 ),
			Robust Mean( 0 ),
			Robust Std Dev( 0 ),
			Set Alpha Level( 0, <<Off ),
			Set Trimmed Mean Percent( 0, <<Off ),
			Show All Modes( 0 )
		DOE(
			Simulate Responses( 0 ),
			Suppress Cotter Designs( 1 ),
			Save X Matrix( 0 ),
			Discrete Numeric Powers Set to Necessary( 0 ),
			Blue to Gray to Red( 0 ),
			Optimality Criterion( "Recommended", <<Off ),
			ALT Optimality Criterion( "Make D-Optimal Design", <<Off ),
			FFF Optimality Criterion( "MaxPro", <<Off ),
			Design Search Time( 0, <<Off ),
			Use Bayesian information( 0 )
		Effect Fit(
			LSMeans Table( 1 ),
			LSMeans Plots( 0 ),
			LSMeans Student's t( 0 ),
			LSMeans Tukey HSD( 0 ),
			LSMeans Dunnett( 0 ),
			Test Slices( 0 )
		EMP Average Chart(
			Show Grand Mean( 1 ),
			Show Connected Means( 1 ),
			Show Control Limits Shading( 1 ),
			Show Separators( 1 ),
			Show Data( 0 )
		EMP Dispersion Chart(
			Show Average Dispersion( 1 ),
			Show Connected Points( 1 ),
		EMP Measurement Systems Analysis(
			Average Chart( 1 ),
			Dispersion Chart( 1 ),
			Dispersion Chart Type( "Range", <<Off ),
			Show Part Legend( 1 ),
			Parallelism Plots( 0 ),
			EMP Results( 0 ),
			Show Monitor Classification Legend( 1 ),
			Effective Resolution( 0 ),
			Bias Comparison( 0 ),
			Name( "Test-Retest Error Comparison" )(0),
			Shift Detection Profiler( 0 ),
			Show Shift Detection Profiler Legend( 1 ),
			Variance Components( 0 ),
			Name( "EMP Gauge R&&R Results" )(0),
			MSA Method( "EMP", <<Off ),
		Equivalence Test( Equivalence TOST Tests( 1 ), Equivalence Tests Scatterplot( 1 ) ),
		Excel Profiler( Prediction Profiler( 0 ), Save Expanded Formulas( 0 ), Expand Intermediate Formulas( 0 ), Report View( "Full", <<Off ) ),
		Explore Missing Values(
			Select Rows( 0 ),
			Exclude Rows( 0 ),
			Color Rows( 0 ),
			Color Cells( 0 ),
			Show only columns with missing( 0 ),
			Close( 0 ),
			Undo Imputation( 0 ),
		Explore Outliers(
			Quantile Range Outliers( 0 ),
			Robust Fit Outliers( 0 ),
			Multivariate Robust Outliers( 0 ),
			Name( "Multivariate k-Nearest Neighbor Outliers" )(0),
			Tail Quantile( 0.1, <<Off ),
			Q( 3, <<Off ),
			Restrict search to integers( 0 ),
			Show only columns with outliers( 0 ),
			K Sigma( 4, <<Off ),
			Huber( 0 ),
			Cauchy( 0 ),
			Quartile( 0 ),
		Explore Patterns(
			Most Duplicated Values( 1 ),
			Longest Runs( 1 ),
			Longest Duplicated Sequences( 1 ),
			Formatted Widths( 0 ),
			Fraction Length( 0 ),
			Leading and Trailing Digits( 0 ),
			Spec Limit Matches( 0 ),
			Distribution wrt Spec Limits( 0 ),
			Duplicates Across Columns( 0 ),
			Colorize Duplicates Across Columns( 0 ),
			Linear Relationships( 0 ),
			Colorize Linear Relationships( 0 ),
			Clear Cell Colors( 0 ),
			Minimum Run Size( 2, <<Off ),
			Minimum Longest Duplicate Size( 2, <<Off ),
			Minimum Cross Column Duplicate Run Size( 2, <<Off ),
			Minimum Rows for Linear Relationship( 10, <<Off ),
			Include Missing( 0 ),
		Factor Analysis(
			Variance Estimation( "Default", <<Off ),
			Variance Scaling( "Correlations", <<Off ),
			Eigenvalues( 1 ),
			Scree Plot( 1 ),
			Suppress Absolute Loading Value Less Than( 0.3, <<Off ),
			Dim Text( 0.4, <<Off ),
		Factor Analysis Fit Options(
			Prior Communality( 0 ),
			Eigenvalues( 0 ),
			Unsorted and Unrotated Factor Loading( 0 ),
			Rotation Matrix( 0 ),
			Interfactor Correlations( 0 ),
			Final Communality Estimates( 1 ),
			Standard Score Coefficients( 0 ),
			Variance Explained by Each Factor( 1 ),
			Significance Test( 1 ),
			Measures of Fit( 1 ),
			Measures of Factor Scores( 0 ),
			Unsorted and Rotated Factor Loading( 1 ),
			Factor Loading Plot( 1 ),
			Score Plot( 0 ),
			Score Plot with Imputation( 0 ),
			Arrow Lines( 1 )
		Fit Curve( Report View( "Full", <<Off ) ),
		Fit Distribution(
			Diagnostic Plot( 0 ),
			Density Curve( 0 ),
			Goodness of Fit( 1 ),
			Save Fitted Quantiles( 0 ),
			Save Density Formula( 0 ),
			Save Spec Limits( 0 ),
			Make Parms Table( 0 ),
			Save Transformed( 0 )
		Fit Generalized Linear Model(
			Inverse Prediction( 0 ),
			Covariance of Estimates( 0 ),
			Profiler( 0 ),
			Contour Profiler( 0 ),
			Surface Profiler( 0 ),
			Studentized Deviance Residuals by Predicted( 1 ),
			Studentized Pearson Residuals by Predicted( 0 ),
			Deviance Residuals by Predicted( 0 ),
			Regression Plot( 1 ),
			Linear Predictor Plot( 0 ),
			Prediction Formula( 0 ),
			Parametric Formula( 0 ),
			Predicted Values( 0 ),
			Mean Confidence Interval( 0 ),
			Deviance Residuals( 0 ),
			Pearson Residuals( 0 ),
			Studentized Deviance Residuals( 0 ),
			Studentized Pearson Residuals( 0 ),
			Effect Summary( 1 ),
			FDR( 0 ),
		Fit Group( Arrange in Rows( 0, <<Off ), Order by Goodness of Fit( 0 ), Report View( "Full", <<Off ) ),
		Fit Least Squares(
			Profiler( 0, <<Off ),
			Cube Plots( 0 ),
			Mixture Profiler( 0 ),
			Summary of Fit( 0, <<Off ),
			Analysis of Variance( 0, <<Off ),
			Parameter Estimates( 0, <<Off ),
			Effect Tests( 1 ),
			Effect Details( 1 ),
			Lack of Fit( 1 ),
			Show All Confidence Intervals( 0 ),
			Show VIF( 0 ),
			AICc( 0 ),
			Show Prediction Expression( 0 ),
			Sorted Estimates( 0 ),
			Expanded  Estimates( 0 ),
			Indicator Parameterization Estimates( 0 ),
			Sequential Tests( 0 ),
			Cox Mixtures( 0 ),
			Parameter Power( 0 ),
			Error Specification( "Default Estimate", <<Off ),
			Scaled Estimates( 0, <<Off ),
			Normal Plot( 0 ),
			Bayes Plot( 0 ),
			Pareto Plot( 0 ),
			Interaction Plots( 0 ),
			Box Cox Y Transformation( 0, <<Off ),
			Plot Regression( 1 ),
			Plot Actual by Predicted( 0, <<Off ),
			Plot Effect Leverage( 0, <<Off ),
			Plot Residual by Predicted( 0, <<Off ),
			Plot Residual by Row( 0 ),
			Plot Studentized Residuals( 0, <<Off ),
			Plot Residual by Normal Quantiles( 0, <<Off ),
			Press( 0 ),
			Durbin Watson Test( 0 ),
			Residuals( 0 ),
			Indiv Confidence Interval( 0 ),
			Hats( 0 ),
			Std Error of Predicted( 0 ),
			Std Error of Residual( 0 ),
			Std Error of Individual( 0 ),
			Effect Leverage Pairs( 0 ),
			Cook's D Influence( 0 ),
			StdErr Pred Formula( 0 ),
			Conditional Pred Formula( 0 ),
			Conditional Pred Values( 0 ),
			Conditional Residuals( 0 ),
			Conditional Mean CI( 0 ),
			Conditional Indiv CI( 0 ),
			Parameterized Formula( 0 ),
			FDR( 0 ),
		Fit Life by X(
			Confidence Interval Method( "Wald", <<Off ),
			Show Points( 1 ),
			Transposed Axes( 0 ),
			Maximum Iterations( 0, <<Off ),
			Rejection Sampler Maximum Trials( 10000, <<Off ),
		Response Fit LogVariance(
			Variance Formula( 0 ),
			Std Dev Formula( 0 ),
			Residuals( 0 ),
			Plot Actual by Predicted( 1 ),
			Plot Studentized Residual by Predicted( 0 ),
			Plot Studentized Residual by Row( 0 ),
			Profiler( 0 ),
		Fit Manova(
			Response Function( "Repeated Measures", <<Off ),
			Save Discrim( 0 ),
			Save Predicted( 0 ),
			Save Residuals( 0 ),
		Fit Nominal Logistic(
			Logistic Plot( 1 ),
			Show Points( 1 ),
			Show Rate Curve( 0 ),
			Likelihood Ratio Tests( 0, <<Off ),
			Wald Tests( 0, <<Off ),
			Odds Ratios( 0 ),
			ROC Curve( 0 ),
			Lift Curve( 0 ),
			Confusion Matrix( 0 ),
			Specify Profit Matrix( 0 ),
			Profiler( 0 ),
			FDR( 0 ),
		Fit Ordinal Logistic(
			Logistic Plot( 1 ),
			Wald Tests( 0 ),
			ROC Curve( 0 ),
			Lift Curve( 0 ),
			Profiler( 0 ),
			Save Probability Formula( 0 ),
			FDR( 0 ),
		Fit Parametric Survival(
			Name( "Include location-scale distributions in All Distributions" )(0),
			Likelihood Confidence Intervals( 0 ),
			Residual Probability Plot( 0 ),
			Distribution Plot by Level Combinations( 0 ),
			FDR( 0 ),
		Fit Proportional Hazards(
			Risk Ratios( 0 ),
			FDR( 0 ),
		Fit Response Screening( Report View( "Full", <<Off ) ),
		Fit Stepwise(
			Prob to Enter( 0, <<Off ),
			Prob to Leave( 0, <<Off ),
			Direction( "Forward", <<Off ),
			Rules( "Combine", <<Off ),
			Stopping Rule( "Minimum BIC", <<Off ),
			Enter All( 0 ),
			Remove All( 0 ),
			Name( "K-Fold Crossvalidation" )(0),
			All Possible Models( 0 ),
			Model Averaging( 0 ),
			Plot Criterion History( 0 ),
			Plot RSquare History( 0 ),
			Clear History( 0 ),
			Export Model With Validation( 0 ),
		Gaussian Process(
			Estimate Nugget( 0 ),
			Set Correlation Function( "Cubic", <<Off ),
			Set Minimum Theta( 0, <<Off ),
			Set Nugget( 0, <<Off ),
			Profiler( 0 ),
		Graph Builder(
			Show Legend( 1 ),
			Legend Position( "Right", <<Off ),
			Lighten large fills( 1 ),
			Use row colors for levels( 1 ),
			Show Title( 1 ),
			Show Subtitle( 1 ),
			Title Alignment( "Left", <<Off ),
			Title Span( "Full", <<Off ),
			Subtitle Alignment( "Left", <<Off ),
			Subtitle Span( "Full", <<Off ),
			Show Footer( 1 ),
			Lock Scales( 0 ),
			Link Page Axes( "None", <<Off ),
			Sampling( 0, <<Off ),
			Graph Spacing( 1, <<Off ),
			Page Gap Size( 25, <<Off ),
			Page Count Limit( 200, <<Off ),
			Include Missing Categories( 0 ),
			Set α Level( "0.05", <<Off ),
			Show Excluded Rows( 0 ),
			Continuous Points Limit( 50000, <<Off ),
			Continuous Alternate( "None", <<Off ),
			Continuous Smoother( 1 ),
			Smoothing Parameter( 0.05, <<Off ),
			Categorical Points Limit( 5000, <<Off ),
			Categorical Alternate( "Box Plot", <<Off ),
			Jitter( 1 ),
			Missing Shapes( 0 ),
			Graph Width( 0, <<Off ),
			Graph Height( 0, <<Off ),
			X Group Edge( "Top", <<Off ),
			Y Group Edge( "Left", <<Off ),
			Y Group Level Orientation( "Horizontal", <<Off ),
			Y Group Title Orientation( "Horizontal", <<Off ),
			Summary Statistic( "Mean", <<Off ),
			Order Statistic( "Mean", <<Off ),
			Back Color( 2147483647, <<Off ),
			Grid Color( -14540253, <<Off ),
			Grid Transparency( 1, <<Off ),
			Spacing Borders( 0 ),
			Title Fill Color( -14408138, <<Off ),
			Title Text Color( 0, <<Off ),
			Title Frame Color( -14408138, <<Off ),
			Title Transparency( 1, <<Off ),
			Title Underline( 0 ),
			Level Fill Color( -15329503, <<Off ),
			Level Text Color( 0, <<Off ),
			Level Frame Color( -14408138, <<Off ),
			Level Transparency( 1, <<Off ),
			Level Spacing Color( -14540253, <<Off ),
			Level Spacing Transparency( 1, <<Off ),
			Level Underline( 0 ),
			Page Level Fill Color( -13421242, <<Off ),
			Page Level Text Color( 0, <<Off ),
			Page Level Frame Color( -13421242, <<Off ),
			Page Level Transparency( 1, <<Off ),
			Page Level Underline( 0 ),
		Hierarchical Cluster(
			Color Clusters( 0 ),
			Mark Clusters( 0 ),
			Cluster Criterion( 0 ),
			Show Dendrogram( 1 ),
			Dendrogram Scale( "Distance Scale", <<Off ),
			Distance Graph( 1 ),
			Show NCluster Handle( 1 ),
			Zoom to Selected Rows( 0 ),
			Release Zoom( 0 ),
			Pivot on Selected Cluster( 0 ),
			Color Map( "None", <<Off ),
			Two Way Clustering( 0 ),
			Row Dendrogram Position( "Left", <<Off ),
			Row Label Position( "Left", <<Off ),
			Row More Position( "Left", <<Off ),
			Column Dendrogram Position( "Below", <<Off ),
			Column Label Position( "Below", <<Off ),
			Legend( 0 ),
			More Color Map Columns( 0 ),
			Save Cluster Means( 0 ),
			Cluster Summary( 0 ),
			Parallel Coord Plots( 0 ),
			Hide Distance Messages( 0 ),
			Cluster Treatment Comparisons( 0 ),
			Standardize Robustly( 0 ),
			Missing value imputation( 0 ),
			Standardize Data( 0 ),
			Method( "Ward", <<Off ),
			Add Spatial Measures( 0 ),
		Item Analysis( Number of Plots Across( 0, <<Off ), Save Ability Formula( 0 ), Model( "Logistic 2PL", <<Off ), Report View( "Full", <<Off ) ),
		JMP App( Snap To Grid( 1 ), Show Grid( 1 ), Auto Scroll( 1 ), Group By Category( 0 ) ),
		JMP App Module( Auto Launch( 1 ) ),
		K Means Cluster(
			SOM( 0 ),
			Columns Scaled Individually( 1 ),
			Use within cluster std dev( 0 ),
			Shift distances by rates( 0 ),
			Max Iterations( 0, <<Off ),
			SOM Bandwidth( 0, <<Off ),
			SOM N Rows( 0, <<Off ),
			Number of Clusters( 0, <<Off ),
		K Means Fit(
			Biplot( 0 ),
			Biplot Contour Density( 0, <<Off ),
			Mark Clusters( 0 ),
			Biplot 3D( 0 ),
		Latent Class Analysis(
			Number of Clusters( 3, <<Off ),
			Up to( 0, <<Off ),
			New Number of Clusters( 0, <<Off ),
		LCA Fit(
			Model Summary( 1 ),
			Parameter Estimates( 1 ),
			Transposed Parameter Estimates( 0 ),
			Effect Sizes( 1 ),
			MDS Plot( 1 ),
			Mixture Probabilities( 0 )
		Life Distribution(
			Fit LogGenGamma( 1 ),
			Fit GenGamma( 1 ),
			Fit TH Weibull( 1 ),
			Fit TH Lognormal( 1 ),
			Fit TH Frechet( 1 ),
			Fit TH Loglogistic( 1 ),
			Fit ZI Weibull( 1 ),
			Fit ZI Lognormal( 1 ),
			Fit ZI Frechet( 1 ),
			Fit ZI Loglogistic( 1 ),
			Fit DS Weibull( 1 ),
			Fit DS Lognormal( 1 ),
			Fit DS Frechet( 1 ),
			Fit DS Loglogistic( 1 ),
			Show Points( 1 ),
			Show Shaded Pointwise Intervals( 0 ),
			Show Shaded Simultaneous Intervals( 0 ),
			Show Staircase Style Function( 0 ),
			Show Legacy Combined Table( 0 ),
			Show Event Plot Frequency Label( 1 ),
			Show Markers for Right Censored Observations( 1 ),
			Show Survival Curve( 0 ),
			Show Quantile Functions( 0 ),
			Show Hazard Functions( 0 ),
			Show Statistics( 1 ),
			Tabbed Report( 0 ),
			Show Confidence Area( 1 ),
			Interval Type( "Simultaneous", <<Off ),
			Preferred Prior Type( "Location and Scale Priors", <<Off ),
			Get Formula( 0 ),
			Weibayes Only for Zero Failure Data( 1 ),
		Name( "Life Distribution - Compare Groups" )(Show Points( 1 ), Show Survival Curve( 0 ), Tabbed Report( 0 ), Show Quantile Functions( 0 ),
		Show Hazard Functions( 0 ), Show Density Functions( 0 ), Show Confidence Area( 1 ), Interval Type( "Simultaneous", <<Off ),
		Estimate Probability( 0 ), Estimate Quantile( 0 ), Report View( "Full", <<Off )),
		Logistic(
			Odds Ratios( 0 ),
			Logistic Plot( 1 ),
			Show Points( 1 ),
			ROC Curve( 0 ),
			Lift Curve( 0 ),
			Reverse Y Levels( 0 ),
		LSMeans Comparisons(
			Crosstab Report( 1 ),
			Connecting Letters Report( 1 ),
			Save Connecting Letters Table( 0 ),
			Ordered Differences Report( 0 ),
			Detailed Comparisons( 0 ),
			Control Differences Report( 1 ),
			Control Differences Chart( 0 )
		Manage Spec Limits(
			Load from Limits Table( 0 ),
			Save to Column Properties( 0 ),
			Save to Tall Spec Limits Table( 0 ),
			Save to Wide Spec Limits Table( 0 ),
			Show Limits All( 0 ),
			Round Decimals( 0 ),
			Color Out of Spec Values( 0 ),
		Matched Pairs(
			Plot Dif By Mean( 1 ),
			Plot Dif By Row( 0 ),
			Reference Frame( 1, <<On ),
			Wilcoxon Signed Rank( 0 ),
			Sign Test( 0 ),
			Set α Level( "0.01", <<Off ),
		Mixture Profiler Graph(
			Ref Labels( 1 ),
			Ref Lines( 1 ),
			Show Points( 1 ),
			Show Current Value( 1 ),
			Show Constraints( 1 ),
			Up Dots( 1 ),
		Model Dialog(
			Keep dialog open( 0 ),
			Center Polynomials( 1 ),
			Informative Missing( 0 ),
			Robust Fit( 0 ),
			Cauchy Fit( 0 ),
			Fit Separately( 0 ),
			Choose High Target( 0 ),
			Emphasis( "Effect Leverage", <<Off ),
			Scaling( 1 ),
			Centering( 1 ),
			Standardize X( 1 ),
			Impute Missing Data( 0 ),
			Imputation Method( "Mean", <<Off ),
			Convergence Limit( 0, <<Off ),
			Method( "REML", <<Off ),
			NoBounds( 1 ),
			Censor Code( 0 ),
			To Data Table( 0 ),
			To Journal( 0 ),
			To Script Window( 0 ),
			To Report( 0 ),
			To Clipboard( 0 ),
			Name( "To Data Table (All Objects)" )(0),
			Name( "To Script Window (All Objects)" )(0),
			Get Script( 0 ),
			Get Script With Data Table( 0 ),
			Get Data Table( 0 ),
			Report( 0 ),
			Top Report( 0 ),
			Title( 0 )
		Model Driven Multivariate Control Chart(
			Show History Summary Statistics( 0 ),
			Show Monitoring Plots( 0 ),
			Set Component( 0, <<Off ),
			T² Plot( 0 ),
			Normalized DModX Plot( 0 ),
			Squared Prediction Error Plot( 0 ),
			Score Plot( 0 ),
			Diagnose the Process( 0 ),
			Historical Data End at Row( 0, <<Off )
		Multidimensional Scaling(
			MDS Plot( 1 ),
			Shepard Diagram( 1 ),
			Waern Links( 0 ),
			Show Coordinates( 0 ),
			Show Proximity( 0 ),
			Name( "3D Plot" )(0),
			Save Proximity( 0 ),
			Save Coordinates( 0 ),
			Data Format( "Distance Matrix", <<Off ),
			Transformation( "None", <<Off ),
			Set Dimensions( 2, <<Off ),
		Multiple Correspondence Analysis(
			Mosaic Plot( 0 ),
			Cross Table( 1 ),
			Cross Table of Supplementary Rows( 0 ),
			Cross Table of Supplementary Columns( 0 ),
			Tests for Independence( 0 ),
			Show Plot( 1 ),
			Show Detail( 1 ),
			Show Adjusted Inertia( 0 ),
			Show Summary Statistics( 0 ),
			Show Partial Contributions to Inertia( 0 ),
			Show Squared Cosines( 0 ),
			Cochran's Q Test( 0 ),
			Name( "3D Correspondence Analysis" )(0),
			Save Coordinate Formula( 0 ),
		Multiple Factor Analysis(
			Contingency Table Format( 0 ),
			Block Weights( 0 ),
			Eigenvalues( 0 ),
			Eigenvectors( 0 ),
			Variable Loadings( 0 ),
			Variable Partial Contributions( 0 ),
			Variable Squared Cosines( 0 ),
			Summary Plots( 1 ),
			Consensus Map( 1 ),
			Biplot( 0 ),
			Partial Axes Plot( 0 ),
			Arrow Lines( 1 ),
			Show Labels( 0 ),
			RV Correlations( 0 ),
			Lg Coefficients( 0 ),
			Block Partial and Consensus Correlations( 0 ),
			Block Partial Contributions( 0 ),
			Block Partial Inertias( 0 ),
			Block Squared Cosines( 0 ),
		Multivariate(
			Correlations Multivariate( 1 ),
			Correlation Probability( 0 ),
			CI of Correlation( 0 ),
			Inverse Correlations( 0 ),
			Partial Correlations( 0 ),
			Partial Correlation Probability( 0 ),
			Covariance Matrix( 0 ),
			Pairwise Correlations( 0 ),
			Hotelling's T² Test( 0 ),
			Univariate Simple Statistics( 0 ),
			Multivariate Simple Statistics( 0 ),
			Spearman's ρ( 0 ),
			Kendall's τ( 0 ),
			Hoeffding's D( 0 ),
			Scatterplot Matrix( 1 ),
			Color Map on Correlations( 0 ),
			Name( "Color Map on p-Values" )(0),
			Cluster the Correlations( 0 ),
			Color Map on Pairwise Correlations( 0 ),
			Color Map on Spearman's ρ( 0 ),
			Color Map on Kendall's τ( 0 ),
			Color Map on Hoeffding's D( 0 ),
			Parallel Coord Plot( 0 ),
			Ellipsoid 3D Plot( 0 ),
			Principal Components( "on Correlations", <<Off ),
			Mahalanobis Distances( 0 ),
			Jackknife Distances( 0 ),
			T²( 0 ),
			Cronbach's α( 0 ),
			Standardized α( 0 ),
			Save Imputed Formula( 0 ),
			Estimation Method( "Default", <<Off ),
			Matrix Format( "Square", <<Off ),
			T Square Chart( 1 ),
			T Square Partitioned( 0, <<Off ),
			Set Alpha Level( "0.05", <<Off ),
			Show Covariance( 0 ),
			Show Correlation( 0 ),
			Show Inverse Covariance( 0 ),
			Show Inverse Correlation( 0 ),
			Show Means( 0 ),
			Change Point Detection( 0 ),
			Principal Components( 0 ),
		Neural( Transform Covariates( 0 ), Validation Method( "Excluded Rows Holdback", <<Off ), Report View( "Full", <<Off ) ),
		Neural Fit(
			Diagram( 0 ),
			Show Estimates( 0 ),
			Profiler( 0 ),
			Categorical Profiler( 0 ),
			Plot Actual by Predicted( 0 ),
			Plot Residual by Predicted( 0 ),
			ROC Curve( 0 ),
			Lift Curve( 0 )
		Neural Net(
			Crossvalidation( "No Crossvalidation", <<Off ),
			Diagram( 0 ),
			Sequence of Fits( 0 ),
			Profiler( 0 ),
			ROC Curve( 0 ),
			Lift Curve( 0 ),
			Save Predicted and Limits( 0 ),
			Save Formulas( 0 ),
			Save Profile Formulas( 0 ),
			Save Hidden and Scaled Cols( 0 ),
			Set Random Seed( 0, <<Off ),
			Log the Tours( 0 ),
			Log the Iterations( 0 ),
			Log the Estimates( 0 ),
			Method( "BFGS", <<Off ),
			Overfit Penalty( 0, <<Off ),
			Number of Tours( 0, <<Off ),
			Converge Criterion( 0, <<Off ),
		Nonlinear(
			Plot( 1 ),
			Iteration Log( 0 ),
			Numeric Derivatives Only( 0 ),
			Second Deriv Method( 0 ),
			Newton( 0 ),
			QuasiNewton SR1( 0 ),
			QuasiNewton BFGS( 0 ),
			Accept Current Estimates( 0 ),
			Show Derivatives( 0 ),
			Unthreaded( 0 ),
			Profiler( 0 ),
			Parameter Profiler( 0 ),
			Parameter Contour Profiler( 0 ),
			Parameter Surface Profiler( 0 ),
			Remember Solution( 0 ),
			Custom Estimate( 0 ),
			Custom Inverse Prediction( 0 ),
			Loss is Neg LogLikelihood( 0, <<Off ),
			Go( 0 ),
			CL Limit( 0, <<Off ),
			CL Alpha( 0, <<Off ),
			Iteration Limit( 0, <<Off ),
			Obj Change Limit( 0, <<Off ),
			Relative Gradient( 0, <<Off ),
			Gradient Limit( 0, <<Off ),
		Normal Mixtures(
			Diagonal Variance( 0 ),
			Outlier Cluster( 0 ),
			Mixtures N Starts( 0, <<Off ),
			Mixtures MaxIter( 0, <<Off ),
			Mixtures Tolerance( 0, <<Off ),
		Normal Mixtures Fit(
			Biplot( 0 ),
			Mark Clusters( 0 ),
			Biplot 3D( 0 ),
		Oneway(
			Quantiles( 0 ),
			Means( 0 ),
			Means and Std Dev( 0 ),
			t Test( 0 ),
			ANOM( 0 ),
			ANOM with Transformed Ranks( 0 ),
			ANOM for Variances( 0 ),
			Name( "ANOM for Variances with Levene(ADM)" )(0),
			ANOM for Ranges( 0 ),
			Each Pair( 0 ),
			All Pairs( 0 ),
			With Best( 0 ),
			With Control( 0 ),
			Each Pair Stepwise( 0 ),
			Wilcoxon Test( 0 ),
			Median Test( 0 ),
			van der Waerden Test( 0 ),
			Friedman Rank Test( 0 ),
			Wilcoxon Exact Test( 0 ),
			Median Exact Test( 0 ),
			Van Der Waerden Exact Test( 0 ),
			Kolmogorov Smirnov Exact Test( 0 ),
			Wilcoxon Each Pair( 0 ),
			Name( "Steel-Dwass All Pairs" )(0),
			Steel With Control( 0 ),
			Dunn All Pairs for Joint Ranks( 0 ),
			Dunn With Control for Joint Ranks( 0 ),
			Unequal Variances( 0 ),
			Equivalence Test( 0 ),
			Robust Fit( 0 ),
			Cauchy Fit( 0 ),
			Power( 0 ),
			Plot Actual by Quantile( 0 ),
			Plot Quantile by Actual( 0 ),
			Line of Fit( 1 ),
			CDF Plot( 0 ),
			Compare Densities( 0 ),
			Composition of Densities( 0 ),
			Proportion of Densities( 0 ),
			All Graphs( 1 ),
			Points( 1 ),
			Box Plots( 0 ),
			Mean Diamonds( 0 ),
			Mean Lines( 0 ),
			Mean CI Lines( 0 ),
			Mean Error Bars( 0 ),
			Grand Mean( 1 ),
			Std Dev Lines( 0 ),
			Comparison Circles( 1 ),
			Connect Means( 0 ),
			Mean of Means( 0 ),
			X Axis Proportional( 1 ),
			Points Spread( 0 ),
			Points Jittered( 0 ),
			Histograms( 0 ),
			Robust Means Lines( 0 ),
			Legend( 1 ),
		Oneway Means Comparisons(
			Difference Matrix( 0 ),
			Confidence Quantile( 1 ),
			LSD Threshold Matrix( 1 ),
			Connecting Letters Report( 1, <<On ),
			Ordered Differences Report( 1, <<On ),
			Detailed Comparisons Report( 0 )
		Overlay Plot(
			Overlay Y's( 1 ),
			Overlay Groups( 0 ),
			No Overlay( 0 ),
			Separate Axes( 1 ),
			Uniform Y Scale( 0 ),
			Connect Thru Missing( 0 ),
			Range Plot( 0 ),
			Show Points( 1 ),
			Needle( 0 ),
			Step( 0 ),
			Function Plot( 0 ),
			Overlay Marker Color( 0, <<Off ),
			Line Width( "Thin", <<Off ),
			Ungroup Plots( 0 ),
			Arrange Plots( "1 Per Row", <<Off ),
			Sort X( 1 ),
			X Log Scale( 0 ),
			Left Y Log Scale( 0 ),
			Right Y Log Scale( 0 ),
		Parallel Plot( Show Reversing Checkboxes( 0 ), Scale Uniformly( 0 ), Center at zero( 0 ), Report View( "Full", <<Off ) ),
		Pareto Plot(
			Percent Scale( 0 ),
			N Legend( 0 ),
			Category Legend( 0 ),
			Pie Chart( 0 ),
			No Plot( 0 ),
			Per Unit Rates( 0 ),
			Test Rate Within Groups( 0 ),
			Test Rates Across Groups( 0 ),
			Show Cum Percent Curve( 1 ),
			Show Cum Percent Axis( 1 ),
			Show Cum Percent Points( 0 ),
			Label Cum Percent Points( 0 ),
			Cum Percent Curve Color( 0, <<Off ),
			Colors( 0, <<Off ),
		Partial Least Squares(
			Validation Method( "KFold", <<Off ),
			Centering( 1 ),
			Scaling( 1 ),
			Method( "SIMPLS", <<Off ),
			Go( 0 ),
			Initial Number of Factors( 0 ),
		Partial Least Squares Fit(
			Percent Variation Plots( 0 ),
			Variable Importance Plot( 0 ),
			VIP vs Coefficients Plots( 0 ),
			Set VIP Threshold( "0.8", <<Off ),
			Overlay Coefficients Plots( 0 ),
			Overlay Loadings Plots( 0 ),
			Scatter Loadings Plot( 0 ),
			Correlation Loading Plot( 0, <<Off ),
			Fit Line( 1 ),
			Show Confidence Band( 0 ),
			Scatter Scores Plots( 0 ),
			Distance Plots( 0 ),
			T Square Plot( 0 ),
			Diagnostics Plots( 0 ),
			Profiler( 0 ),
			Spectral Profiler( 0 ),
			Save Score Formula( 0 )
		Partition(
			Show Points( 1 ),
			Show Tree( 1 ),
			Show Graph( 1 ),
			Show Split Bar( 1 ),
			Show Split Stats( 1 ),
			Show Split Prob( 0 ),
			Show Split Count( 0 ),
			Show Split Candidates( 1 ),
			Sort Split Candidates( 0 ),
			Minimum Size Split( 0, <<Off ),
			Lock Columns( 0 ),
			Small Tree View( 0 ),
			Tree 3D( 0 ),
			Leaf Report( 0 ),
			Column Contributions( 0 ),
			Uplift Graph( 0 ),
			Split History( 0 ),
			K Fold Crossvalidation( 0 ),
			ROC Curve( 0 ),
			Lift Curve( 0 ),
			Show Fit Details( 0 ),
			Profiler( 0 ),
			Color Points( 0 ),
			Informative Missing( 1, <<On ),
			Ordinal Restricts Order( 1 ),
			Use Excluded Rows for Validation( 0 ),
			Validation Portion( 0, <<Off ),
			Initial Splits( 0 )
		PLS(
			Show Points( 1 ),
			Show Confidence Lines( 0 ),
			Distance Plot( 0 ),
			Scores Plots( 0 ),
			Use Cross Validation( 0 ),
			User Specified( 0 ),
			Go( 0 ),
		Predictor Screening( Number Trees( 100, <<Off ), Report View( "Full", <<Off ) ),
			Principal Components( "on Covariances", <<Off ),
			Correlations( 0 ),
			Eigenvalues( 0 ),
			Eigenvectors( 0 ),
			Bartlett Test( 0 ),
			Loading Matrix( 0 ),
			Formatted Loading Matrix( 0 ),
			Squared Cosines of Variables( 0 ),
			Partial Contribution of Variables( 0 ),
			Summary Plots( 1 ),
			Biplot( 0, <<Off ),
			Scatterplot Matrix( 0, <<Off ),
			Scree Plot( 0 ),
			Score Plot( 0, <<Off ),
			Name( "3D Score Plot" )(0),
			Score Ellipses( 0 ),
			Score Ellipse Coverage( "0.90", <<Off ),
			Arrow Lines( 0 ),
			Show Supplementary Variable( 0 ),
			Outlier Analysis( 0 ),
			Factor Analysis( 0 ),
			Cluster Variables( 0 ),
		Process Capability(
			Goal Plot( 1 ),
			Within Sigma Normalized Box Plots( 0 ),
			Name( "Within or Between-and-Within Sigma Normalized Box Plots" )(0),
			Overall Sigma Normalized Box Plots( 0 ),
			Capability Index Plot( 1 ),
			Process Performance Plot( 0 ),
			Within Sigma Summary Report( 0 ),
			Name( "Within or Between-and-Within Sigma Summary Report" )(0),
			Overall Sigma Summary Report( 0 ),
			Select Out of Spec Values( 0 ),
			Save Distributions as Column Properties( 0 ),
			Specify Alpha Level( 0.05, <<Off ),
			Individual Detail Reports Cutoff( 1, <<Off ),
			Name( "AIAG (Ppk) Labeling" )(1),
		Process Capability Analysis(
			Compare Distributions( 0 ),
			Process Summary( 1 ),
			Histogram( 1 ),
			Within Sigma Capability( 1 ),
			Within Sigma Z Benchmark( 0 ),
			Within Sigma Target Index( 0 ),
			Name( "Between-and-Within Sigma Capability" )(1),
			Name( "Between-and-Within Sigma Z Benchmark" )(0),
			Name( "Between-and-Within Sigma Target Index" )(0),
			Overall Sigma Capability( 1 ),
			Overall Sigma Z Benchmark( 0 ),
			Nonconformance( 1 ),
			Interactive Capability Plot( 0 ),
			Nonparametric Density( 1 )
		Process Capability Analysis Comparisons(
			Comparison Details( 1 ),
			Comparison Histogram( 1 ),
			Probability Plots( 0 ),
			Order by Comparison Criterion( " AICc", <<Off )
		Process Capability Analysis Histogram(
			Show Spec Limits( 1 ),
			Show Target( 1 ),
			Show Within Sigma Density( 1 ),
			Name( "Show Between-and-Within Sigma Density" )(1),
			Show Overall Sigma Density( 1 ),
			Show Count Axis( 0 ),
			Show Density Axis( 0 )
		Process Capability Goal Plot(
			Show Within Sigma Points( 0 ),
			Name( "Show Within or Between-and-Within Sigma Points" )(0),
			Show Overall Sigma Points( 1 ),
			Shade Levels( 0 ),
			Label Within Sigma Points( 0 ),
			Name( "Label Within or Between-and-Within Sigma Points" )(0),
			Label Overall Sigma Points( 0 ),
			Defect Rate Contour( 0.0001, <<Off ),
			Capability Lines( 1, <<Off )
		Process Capability Index Plot(
			Shade Levels( 0 ),
		Process Capability Interactive Plot( Capability( 1 ), Expected PPM( 1 ) ),
		Process Capability Performance Plot(
			Label Points( 0 ),
			Show Within Cpk Curve( 1 ),
			Capability Boundary( 1, <<Off ),
			Stability Boundary( 1.25, <<Off )
		Process Capability Probability Plots(
			Simultaneous Empirical Confidence Limits( 1 ),
			Simultaneous Empirical Confidence Limits Shading( 1 ),
			Parametric Fit Line( 1 ),
			Parametric Fit Confidence Limits Shading( 0 )
		Process History Explorer(
			Goal is to Minimize Y( 0 ),
			Levels with Lowest Yield( 1 ),
			Levels with Lowest Yield with Time Filter( 1 ),
			Stepwise Regression( 0 ),
			Waiting Time Analysis( 0 ),
			Utilization( 0 ),
			Transition Analysis( 0 ),
			Order Interaction( 0 ),
			Save Count Table( 0 ),
			Save Log Count Table( 0 ),
			Save Waiting Time( 0 ),
		Process Screening(
			Control Chart Type( "Indiv and MR", <<Off ),
			Subgroup Sample Size( 5, <<Off ),
			Use Medians instead of Means( 0 ),
			Shift Threshold( 3, <<Off ),
			Outlier Threshold( 5, <<Off ),
			Shift Lambda( 0.3, <<Off ),
			Drift Beta( 0.05, <<Off ),
			Minimum Process Length( 3, <<Off ),
			Summary( 1 ),
			Stability Index( 1 ),
			Stability Ratio( 0 ),
			Within Sigma( 1 ),
			Overall Sigma( 1 ),
			Mean( 1 ),
			Count( 1 ),
			Subgroups( 1 ),
			Show Tests( 1 ),
			Test 1( 1 ),
			Test 2( 0 ),
			Test 3( 0 ),
			Test 4( 0 ),
			Test 5( 0 ),
			Test 6( 0 ),
			Test 7( 0 ),
			Test 8( 0 ),
			Range Limit Exceeded( 0 ),
			Moving Range Limit Exceeded( 0 ),
			Largest Upshift( 0 ),
			Largest Downshift( 0 ),
			Shift Graph( 0 ),
			Show Shifts in Quick Graphs( 0 ),
			Drift Summaries( 0 ),
			Drift Graph Selected( 1 ),
			Drift Alpha( 0, <<Off ),
			Process Performance Graph( 0 ),
			Ppk Capability Boundary( 1.33, <<Off ),
			Stability Index Boundary( 1.25, <<Off ),
			Goal Plot( 0 ),
			Ppk( 1 ),
			Cpk( 1 ),
			Cp( 0 ),
			Target Index( 0 ),
			Out of Spec Count( 1 ),
			Out of Spec Rate( 1 ),
			Expected Out of Spec Rate( 0 ),
			Latest Out of Spec( 1 ),
			Spec Centered Mean( 0 ),
			Spec Scaled Std Dev( 0 ),
			Spec Limits( 0 ),
		Profiler Graph(
			Desirability Functions( 0 ),
			Simulator( 0 ),
			Prop of Error Bars( 0 ),
			Sensitivity Indicator( 0 ),
			Profile at Boundary( "Turn at Boundaries", <<Off ),
			Default N Levels( 0, <<Off ),
			Prediction Intervals( 0 ),
			Reorder X Variables( 0, <<Off ),
			Reorder Y Variables( 0, <<Off ),
			Adapt Y Axis( 0 ),
			Show Creator( 0 ),
		Reliability Forecast( Forecast Options Animation( 1 ), Report View( "Full", <<Off ) ),
		Reliability Growth( Get Results( 0 ), Cumulative Events Plot( 0 ), Mean Time Between Failures Plot( 0 ), Report View( "Full", <<Off ) ),
		Response Fit(
			Effect Tests( 1 ),
			Lack of Fit( 1 ),
			Show VIF( 0 ),
			AICc( 0 ),
			Cox Mixtures( 0 ),
			Normal Plot( 0 ),
			Bayes Plot( 0 ),
			Pareto Plot( 0 ),
			Profiler( 0 ),
			Cube Plots( 0 ),
			Press( 0 ),
			Residuals( 0 ),
			Hats( 0 ),
			FDR( 0 ),
		Response Screening(
			Robust( 0 ),
			Cauchy( 0 ),
			Poisson Y( 0 ),
			Kappa( 0 ),
			Corr( 0 ),
			Same Y Scale( 0 ),
			Missing is category( 0 ),
			Force X Categorical( 0 ),
			Force X Continuous( 0 ),
			Force Y Categorical( 0 ),
			Force Y Continuous( 0 ),
			Paired X and Y( 0 ),
			Unthreaded( 0 ),
			Practical Difference Portion( 0, <<Off ),
			MaxLogWorth( 0, <<Off ),
		Scatterplot 3D(
			Show Points( 1 ),
			Drop Lines( 0 ),
			Jitter( 1 ),
			Sized Points( 0 ),
			Normal Contour Ellipsoids( 0 ),
			Ellipsoid Coverage( 0.5, <<Off ),
			Ellipsoid Transparency( 0.5, <<Off ),
			Nonpar Density Contour( 0 ),
			Drop Line Thickness( 0.03, <<Off ),
			Std Prin Components( 0 ),
			Rotated Components( 0 ),
			Biplot Rays( 0, <<Off ),
			Show Ray Labels( 1 ),
			Biplot ray thickness( 3, <<Off ),
		Scatterplot Matrix(
			Show Points( 1 ),
			Fit Line( 0 ),
			Density Ellipses( 0 ),
			Shaded Ellipses( 0 ),
			Ellipses Coverage( "0.90", <<Off ),
			Ellipses Transparency( "0.20", <<Off ),
			Ellipse Color( 0, <<Off ),
			Lock Scales( 0 ),
			Matrix Format( "Lower Triangular", <<Off ),
		Score Ellipse Coverage( Shaded Contour( 0 ) ),
		Simulator( N Strata( 0, <<Off ), Set Random Seed( 0, <<Off ) ),
		Surface Plot(
			Show Density Data Points( 1 ),
			Show Surface( "Both sides", <<Off ),
			Show Surface2( "Off", <<Off ),
			Show Surface3( "Off", <<Off ),
			Show Surface4( "Off", <<Off ),
			Show Mesh( "Off", <<Off ),
			Show Mesh2( "Off", <<Off ),
			Show Mesh3( "Off", <<Off ),
			Show Mesh4( "Off", <<Off ),
			Show Contour( "Off", <<Off ),
			Show Contour2( "Off", <<Off ),
			Show Contour3( "Off", <<Off ),
			Show Contour4( "Off", <<Off ),
			Lock Z Scale( 0 ),
			Show formula( 0 ),
			Hide Lights Border( 0 ),
			Surface Selector( 1 ),
			Dependent Variables Color( 1 ),
			Dependent Variables Mesh( 0 ),
			Dependent Variables Contour( 0 ),
			Dependent Variables Points( 1 ),
			Dependent Variables Density( 1 ),
			Dependent Variables Response Grid( 1 ),
			Scale response axes independently( 0 ),
			Datapoints Choice( "Off", <<Off ),
			Datapoints Choice2( "Off", <<Off ),
			Datapoints Choice3( "Off", <<Off ),
			Datapoints Choice4( "Off", <<Off ),
			Datapoint Interpretation( "Off", <<Off ),
			Mode( "Sheet, points", <<Off ),
			Resolution( 41, <<Off ),
			Density Smooth( 0.5, <<Off ),
			Z Grid Position( 0.5, <<Off ),
			XTickLabelSize( 0.15, <<Off ),
			XAxisLabelSize( 0.3, <<Off ),
			Iso Slider Value1( 0, <<Off ),
			Iso Slider Value2( 0, <<Off ),
			Iso Slider Value3( 0, <<Off ),
			Iso Slider Value4( 0, <<Off ),
			Density Slider Value1( 0.2, <<Off ),
			Density Slider Value2( 0.4, <<Off ),
			Density Slider Value3( 0.6, <<Off ),
			Density Slider Value4( 0.8, <<Off ),
			Surface Alpha( 0.5, <<Off ),
			Surface Alpha2( 0.5, <<Off ),
			Surface Alpha3( 0.5, <<Off ),
			Surface Alpha4( 0.5, <<Off ),
			Grid Color( 1, <<Off ),
			Value Color( 1, <<Off ),
			Name Color( 1, <<Off ),
			Axis Color( 1, <<Off ),
			Mesh Color( 20, <<Off ),
			Mesh Color2( 29, <<Off ),
			Mesh Color3( 24, <<Off ),
			Mesh Color4( 22, <<Off ),
			Surface Color Theme( "Green to Black to Red", <<Off ),
			Surface Color Theme2( "Green to Black to Red", <<Off ),
			Surface Color Theme3( "Green to Black to Red", <<Off ),
			Surface Color Theme4( "Green to Black to Red", <<Off ),
			Surface Gradient Type( "Solid", <<Off ),
			Surface Gradient Type2( "Solid", <<Off ),
			Surface Gradient Type3( "Solid", <<Off ),
			Surface Gradient Type4( "Solid", <<Off ),
			Surface Color Range( "Data", <<Off ),
			Surface Color Range2( "Data", <<Off ),
			Surface Color Range3( "Data", <<Off ),
			Surface Color Range4( "Data", <<Off ),
			Surface Color( 68, <<Off ),
			Surface Color2( 77, <<Off ),
			Surface Color3( 72, <<Off ),
			Surface Color4( 70, <<Off ),
			Contour Color( 36, <<Off ),
			Contour Color2( 45, <<Off ),
			Contour Color3( 40, <<Off ),
			Contour Color4( 38, <<Off ),
			Surface Gradients( 5, <<Off ),
			Surface Gradients2( 5, <<Off ),
			Surface Gradients3( 5, <<Off ),
			Surface Gradients4( 5, <<Off ),
			Data points Color( 52, <<Off ),
			Data points Color2( 61, <<Off ),
			Data points Color3( 56, <<Off ),
			Data points Color4( 54, <<Off ),
			Response Column Fill( "Solid", <<Off ),
			Response Column Fill2( "Solid", <<Off ),
			Response Column Fill3( "Solid", <<Off ),
			Response Column Fill4( "Solid", <<Off ),
			Response Column Gradients( 5, <<Off ),
			Response Column Gradients2( 5, <<Off ),
			Response Column Gradients3( 5, <<Off ),
			Response Column Gradients4( 5, <<Off ),
			Response Column Color Theme( "Green to Black to Red", <<Off ),
			Response Column Color Theme2( "Green to Black to Red", <<Off ),
			Response Column Color Theme3( "Green to Black to Red", <<Off ),
			Response Column Color Theme4( "Green to Black to Red", <<Off ),
		Survival(
			Survival Plot( 1 ),
			Failure Plot( 0, <<Off ),
			Show Points( 0 ),
			Show Kaplan Meier( 1 ),
			Show Combined( 0 ),
			Show Confid Interval( 0 ),
			Show Simultaneous CI( 0 ),
			Show Shaded Pointwise CI( 0 ),
			Show Shaded Simultaneous CI( 0 ),
			Midstep Quantile Points( 1 ),
			Connect Quantile Points( 1 ),
			Fitted Quantile( 0 ),
			Fitted Quantile CI Lines( 0 ),
			Fitted Quantile CI Shaded( 0 ),
			Fitted Survival CI( 0 ),
			Fitted Failure CI( 0 ),
			Exponential Plot( 0 ),
			Exponential Fit( 0 ),
			Weibull Plot( 0 ),
			Weibull Fit( 0 ),
			LogNormal Plot( 0 ),
			LogNormal Fit( 0 ),
			Fitted Distribution Plots( 0 ),
			Competing Causes( 0 ),
			Save Estimates( 0 ),
			Plot Failure Instead of Survival( 0 ),
		Tabulate(
			Columns by Categories( 0 ),
			Name( "N (No Analysis Column)" )(1),
			Name( "Sum (For Analysis column)" )(1),
			Name( "% of Total" )(0),
			Mean( 0 ),
			Std Dev( 0 ),
			Min( 0 ),
			Max( 0 ),
			Add Aggregate Statistics( 0 ),
			Include missing for grouping columns( 0 ),
			Order by count of grouping columns( 0 ),
			Uniform plot scale( 1 ),
			Show Table( 1 ),
			Show Chart( 0 ),
			Show Shading( 1 ),
			Show Tooltip( 0 ),
			Show Test Build Panel( 0 ),
			Full Path Column Name( 0 ),
		Ternary Plot(
			Ref Labels( 1 ),
			Ref Lines( 1 ),
			Contour Fill( "Lines only", <<Off ),
			Name( "3D Graph" )(0),
			Show Points( 1 ),
		Text Explorer(
			Show Word Cloud( 0 ),
			Show Term List( 1 ),
			Show Phrase List( 1 ),
			Show Term and Phrase Options( 0 ),
			Show Summary Counts( 1 ),
			Show Stop Words( 0 ),
			Show Recodes( 0 ),
			Show Specified Phrases( 0 ),
			Show Stem Exceptions( 0 ),
			Show Delimiters( 0 ),
			Show Stem Report( 0 ),
			Show Selected Rows( 0 ),
			Show Filters for all Tables( 0 ),
			Language( "English", <<Off ),
			Maximum Words per Phrase( 4, <<Off ),
			Minimum Frequency for Phrase( 0, <<Off ),
			Maximum Number of Phrases( 5000, <<Off ),
			Minimum Characters per Word( 1, <<Off ),
			Maximum Characters per Word( 50, <<Off ),
			Stemming( "No Stemming", <<Off ),
			Include Builtin Stop Words( 1 ),
			Include Builtin Phrases( 1 ),
			Tokenizing( "Regex", <<Off ),
			Customize Regex( 0 ),
			Treat Numbers as Words( 0 ),
			Terms Alphabetical( 0 ),
			Phrases Alphabetical( 0 ),
			Layout( "Ordered", <<Off ),
			Coloring( "None", <<Off ),
			Show Legend( 1 ),
			Number of Singular Vectors( 100, <<Off ),
		Time Series(
			Time Series Graph( 1 ),
			Show Points( 1 ),
			Connecting Lines( 1 ),
			Mean Line( 1 ),
			Autocorrelation( 1 ),
			Partial Autocorrelation( 1 ),
			Suppress Lag 0 in ACF and PACF( 0 ),
			Variogram( 0 ),
			AR Coefficients( 0 ),
			Spectral Density( 0 ),
			Cross Correlation( 0 ),
			Save Spectral Density( 0 ),
			Number of Forecast Periods( 0, <<Off ),
			Autocorrelation Lags( 25, <<Off ),
			Simple Moving Average Centering Method( "No Centering", <<Off ),
		Time Series Forecast( Sample Size for Exploration( 10000, <<Off ), Automatic Recalc( 0 ), Report View( "Full", <<Off ) ),
		Treemap(
			Change Color Column( 0 ),
			Color Range( 0 ),
			Legend( 0 ),
			Group Horizontal( 0 ),
			Layout( "Split", <<Off ),
			Auto Stretching( 1 )
		Variability Chart(
			Vertical Charts( 0 ),
			Variability Chart( 1 ),
			Show Points( 1 ),
			Show Range Bars( 1 ),
			Show Cell Means( 1 ),
			Connect Cell Means( 0 ),
			Show Grand Mean( 0 ),
			Show Grand Median( 0 ),
			Show Box Plots( 0 ),
			Mean Diamonds( 0 ),
			XBar Control Limits( 0 ),
			Show Standard Mean( 0 ),
			Variability Summary Report( 0 ),
			Std Dev Chart( 1 ),
			Mean of Std Dev( 0 ),
			S Control Limits( 0 ),
			Group Means of Std Dev( 0 ),
			Heterogeneity of Variance Tests( 0 ),
			Analysis Type( "Choose best analysis (EMS REML Bayesian)", <<Off ),
			Name( "Gauge R&&R Report" )(0),
			Discrimination Ratio( 0 ),
			Misclassification Probabilities( 0 ),
			Name( "Reduced Gauge R&&R Report" )(0),
			Bias Report( 0 ),
			Linearity Study( 0 ),
			Mean Plots( 0 ),
			Std Dev Plots( 0 ),
			AIAG Labels( 1 ),
			K( 0, <<Off ),
			Name( "Show Gauge R&R Specifications Dialog" )(1),
Try(
	Set Preferences(
		Show the Tip of the Day at startup( 0 ),
		Initial Splash Window( 1 ),
		Initial Log Window( 0 ),
		Initial JMP Window( "Home Window" ),
		Reopen the initial JMP window on last window close( 1 ),
		Excel Open Method( "Use Excel Wizard" ),
		Excel Has Labels( 0 ),
		Use Excel Labels as Headings( "Use best guess" ),
		Image Format for PowerPoint( "Default OS format" ),
		Open the file after export( 1 ),
		Multiple File Import Close Window After Import( 0 ),
		Use SPSS labels for column names during import( 1 ),
		SPSS Enable Multiple Response( 1 ),
		Name( "Use Triple-S Labels as Headings" )(1),
		Design of experiments menus( 1 ),
		Quality engineering menus( 1 ),
		Advanced modeling menus( 1 ),
		Reliability and survival menus( 1 ),
		SAS menus( 1 ),
		Excel modeling menus( 1 ),
		Legacy Graphics menus( 1 ),
		Adobe Flash Export Menus( 0 ),
		Show Personalization at startup( 0 ),
		Auto match brackets in script editor( 0 ),
		Retain exact tool positions( 1 ),
		Dock log window( 1 ),
		Log Window Height( 0 ),
		Default filter for File Open( 0 ),
		Initial Window List( 0 ),
		Show window list when windows are maximized( 1 ),
		Auto Run Recent JSL( 0 ),
		Antialias Windows Graphics( 1 ),
		Use EMFPlus for Enhanced Metafiles( 1 ),
		Use JMP Locale Settings( 1 ),
		Task Bar Strategy( "All windows" ),
		Auto Hide Menus( "Based on window size" ),
		Wrap the main menu in narrow windows( 1 ),
		Show the thumbnail panel in data table windows( 1 ),
		Emulate Zoom Mode( 0 ),
		Use Direct2D Graphics( 0 ),
		Save Image DPI( 0 ),
		Use Excel 97 Format( 0 ),
		Enable direct input from IME( 0 ),
		Journal Freeze Backward Compatible( 0 ),
		Save Document Positions( 1 ),
		Enable Hardware Accelerated Graphics( 0 ),
		CrashReport( 1 ),
		Show menu tips( 1 ),
		Next Tip( 1 ),
		Report JSL warnings and errors interactively( 1 ),
		Show log warnings for JSL compatibility changes in JMP 12( 1 ),
		Allow Unquoted Strings in JSL( "Yes (no warning)" ),
		Allow Boolean And Null Constants( 0 ),
		Show Status Bar( 1 ),
		Data Table Side Panel initially closed( 0 ),
		Outline Connecting Lines( 0 ),
		Outline Close Orientation( "Auto" ),
		Formula Boxing( 1 ),
		Outline Markers By Default( 0 ),
		Suppress Format Underflow Detection( 0 ),
		Evaluate OnOpen Scripts( "Prompt" ),
		Prompt to save when closing summary tables( 0 ),
		Allow short numeric data format( 0 ),
		Print Data Grid as is( 0 ),
		Preserve SAS variable names when exporting to SAS( 0 ),
		Preserve SAS formats when exporting to SAS( 1 ),
		Show Alternate Column Name( 0 ),
		Use Thousands Separator( 0 ),
		Default Field Width( 12 ),
		Use a Floating Window for Data Filters( 1 ),
		Data Filter Select Check( 1 ),
		Data Filter Show Check( 0 ),
		Data Filter Include Check( 0 ),
		Data Filter Group is AND( 0 ),
		Data Filter Auto Clear( 0 ),
		Data Filter Conditional( 0 ),
		Data Filter Check Box Display( 0 ),
		Data Filter Histograms and Bars( 1 ),
		Subset Selected Rows( 1 ),
		Subset Selected Columns( 0 ),
		Subset Link To Source( 0 ),
		Subset Copy Formula( 1 ),
		Subset Suppress Formula Evaluation( 1 ),
		Sort Replace Table( 0 ),
		Sort Copy Formula( 1 ),
		Sort Suppress Formula Evaluation( 1 ),
		Data Table Compare Table Variables and Table Scripts( 0 ),
		Data Table Compare Columns Attributes and Properties( 0 ),
		Data Table Compare Data( 1 ),
		Data Table Compare Show Difference Summary( 1 ),
		Data Table Compare Show Difference Plot( 1 ),
		Enter Key moves down( 0 ),
		Numeric keypad Enter key moves down( 0 ),
		Suppress Formula Eval on Open( 0 ),
		ODBC Hide Connection String( 0 ),
		Header summary allowed( 1 ),
		Header summary soft limit( 3000000 ),
		Header summary hard limit( 200000000 ),
		Show summary graphs below column names( 0 ),
		Warn when referenced table name has changed( 1 ),
		Open Text File Charset( "Best Guess" ),
		Save Text Files as Unicode( 1 ),
		Save Journals GZ Compressed( 0 ),
		Save Data Table Columns GZ Compressed( 0 ),
		Allow 16 Bit List Check Compression( 0 ),
		Save Scripts in English( 1 ),
		Display indexes in English( 1 ),
		Report Invalid Display Box Messages( 0 ),
		Add files opened by scripts to the Recent Files list( 1 ),
		Internet Open Timeout( 60 ),
		Proxy Port( 0 ),
		Autosave Timeout( 0 ),
		Autosave Maximum Data Table Rows( 10000 ),
		Autosave Maximum Data Table Columns( 1000 ),
		Hide 'Find and Replace' window( 0 ),
		Use old HTML import( 0 ),
		Show explanations( 0 ),
		Date Title on Output( 0 ),
		Data Table Title on Output( 0 ),
		Hover Help( 1 ),
		Underline Table Headings( 0 ),
		Shade Table Headings( 1 ),
		Table Heading Column Borders( 1 ),
		Table Column Borders( 0 ),
		Table Column Group Borders( 1 ),
		Table Row Borders( 0 ),
		Shade Alternate Table Rows( 0 ),
		Shade Table Cells( 0 ),
		Interactive HTML Color( "Light Background" ),
		Graph Marker size( "Large" ),
		Graph Marker( "Dot" ),
		Graph Marker Theme( "Standard" ),
		Marker Selection Mode( "Unselected Faded" ),
		Marker Label Color Style( "Marker Color" ),
		Continuous Color Theme( "Blue to Gray to Red" ),
		Categorical Color Theme( "JMP Default" ),
		Graph Height( 240 ),
		Fill Selection Mode( "Selected Patterned" ),
		Fill Selection Color( 3 ),
		Graph Border( 0 ),
		Frame Border( 1 ),
		Inside Ticks( 0 ),
		Major Grid Lines( 0 ),
		Minor Grid Lines( 0 ),
		Line Width( 2 ),
		Axis Title Above( 0 ),
		Hide Overlapping Labels( 1 ),
		Major Grid Line Color( -14145495 ),
		Minor Grid Line Color( -15790320 ),
		Frame Color( -10855845 ),
		Name( "Auto-save the report to" )("Prompt"),
		Save table with report( "Prompt" ),
		Automatically save previously saved documents when saving a project( 0 ),
		Save the session when exiting( "Never" ),
		Fast Marker Threshold( 50000 ),
		Graph Marker Unselected Fade( 65 ),
		Selected Marker Color( 3 ),
		Marker Label Color( 80 ),
		Fill Hollow Markers( 0 ),
		Laser pointer( "Off" ),
		Show conditional formatting( "Always" ),
		Use an Asterisk with the PValue Format( 1 ),
		Allow invalid certificates( 1 ),
		Show JMP Public obligation( 1 ),
		JMP Live Timeout( 60 ),
		Show this number of JMP Live bookmarks( 8 ),
		Transparent background for report PNG images( 0 ),
		Local Publish Parent Dir Path( "" ),
		Scripting Index Search Match Options( 0 ),
		Scripting Index Search Index Options( 0 ),
		Scripting Index Search Type Options( 4 ),
		Scripting Index Search Context Mask( 255 ),
		Scripting Index Main Width( 800 ),
		Scripting Index Main Height( 600 ),
		Scripting Index Is Compact( 0 ),
		Scripting Index Expansion Width( 0 ),
		Scripting Index Compact Description Size( 0 ),
		Scripting Index Compact Left Nav Size( 0 ),
		Scripting Index Compact Right Nav Size( 0 ),
		Scripting Index Compact Nav Size( 0 ),
		Scripting Index Compact Example Size( 0 ),
		Scripting Index Full Description Size( 0 ),
		Scripting Index Full Content Size( 0 ),
		Scripting Index Full Nav Size( 0 ),
		Scripting Index Full Example Size( 0 ),
		Scripting Index Show Script Log( 1 ),
		Send Crash Consent( 0 ),
		Use Import Settings( 1 ),
		Import Settings(
			End Of Line( CRLF, CR, LF ),
			End Of Field( Tab, Comma, CSV( 1 ) ),
			Strip Quotes( 1 ),
			Use Regional Settings( 0 ),
			Scan Whole File( 1 ),
			CompressNumericColumns( 0 ),
			CompressAllowListCheck( 0 ),
			Labels( 1 ),
			Column Names Start( 1 ),
			Data Starts( 2 ),
			Lines To Read( "All" ),
			Year Rule( "20xx" )
		Export Settings(
			End Of Line( CRLF ),
			End Of Field( Comma, CSV( 0 ) ),
			Export Table Headers( 1 ),
			Quote all column names( 0 ),
			Quote all character values( 0 ),
			Quote all numeric values( 0 )
		Excel Wizard Settings(
			Use for all sheets( 1 ),
			Concatenate Worksheets( 0 ),
			Create Concatenation Column( 0 ),
			Worksheet Settings(
				1,
				Has Column Headers( 1 ),
				Number of Rows in Headers( 1 ),
				Headers Start on Row( 1 ),
				Data Starts on Row( 2 ),
				Data Starts on Column( 1 ),
				Data Ends on Row( 0 ),
				Data Ends on Column( 0 ),
				Replicated Spanned Rows( 1 ),
				Replicated Spanned Headers( 0 ),
				Suppress Hidden Rows( 1 ),
				Suppress Hidden Columns( 1 ),
				Suppress Empty Columns( 1 ),
				Treat as Hierarchy( 0 ),
				Multiple Series Stack( 0 ),
				Import Cell Colors( 0 ),
				Limit Column Detect( 0 ),
				Column Separator String( "-" )
		FontsDisabled(
			English(
				Text Font( "Segoe UI", 9 ),
				Heading Font( "Segoe UI", 9, "Bold" ),
				Title Font( "Segoe UI", 11, "Bold" ),
				Small Font( "Segoe UI", 7 ),
				Monospaced Font( "Consolas", 10 ),
				Formula Font( "Segoe UI", 11 ),
				Annotation Font( "Segoe UI", 9 ),
				Axis Font( "Segoe UI", 9 ),
				Marker Font( "Segoe UI", 9 ),
				Axis Title Font( "Segoe UI", 9 ),
				Graph Label( "Segoe UI", 9 ),
				Legend( "Segoe UI", 9 ),
				Graph Title( "Segoe UI", 11, "Bold" ),
				Caption( "Segoe UI", 8 ),
				Data Table Font( "Segoe UI", 9 ),
				Control Font( "Segoe UI", 9 ),
				Control Small Font( "Segoe UI", 8 )
		Enable Special Font Effects( 1 ),
		Use Greek letters( 1 ),
		Use math symbols( 1 ),
		Check for Updates( 0 ),
		Update Check Frequency( 2 ),
		Days Since Update Check( 0 ),
		Prompt Check for Updates( 1 ),
		JMP 6 Scoping( 0 ),
		SAS Integration Settings,
		Keep SAS File Type( 0 ),
		Query Builder Settings,
		Script Editor Settings,
		ODBCIgnorePrivileges( 0 ),
		ODBCMultiThreaded( 1 ),
		ODBC Disable Block Fetch( 0 ),
		ODBC Suppress Internal Quoting( 0 ),
		ODBC Disable Binding( 0 ),
		ODBC Disable Delimident( 0 ),
		ODBC Table Options( 25 ),
		ODBC Sample Database( 0 ),
		ODBC Sample Percent( 100 ),
		JSL Debugger Settings,
		Enable JMP Student( 0 ),
		Enable Experimental Features( 0 ),
		Disable Telemetry Prompt( 0 ),
		Disable JMP Pro( 0 ),
		Language Switch Warning( 1 ),
		Maximum JMP Call Depth( 225 ),
		Maximum Symbol Evaluation Recursion Depth( 25 ),
		Maximum Parse Depth( 576 ),
		Formula Editor Width( 800 ),
		Formula Editor Height( 450 ),
		Formula Editor Single Column( 0 ),
		Formula Editor Vars Collapsed( 0 ),
		Formula Editor Max Matrix Size( 4 ),
		Formula Editor First Column Width( -2147483647 ),
		Formula Editor Second Column Width( -2147483647 ),
		Formula Editor Vertical Splitter Height( -2147483647 ),
		Formula Editor Validate Formula( 1 ),
		Formula Editor Show Messages View( 0 ),
		Formula Editor Show Data Preview( 1 ),
		Recode Commit Style( 1 ),
		Recode Store As Steps( 1 ),
		Recode Compress Steps( 1 ),
		Max Data Table Rows for Auto Select( 10000000 ),
		Recode Multiple Response Remove Empty( 0 ),
		Recode Multiple Response Remove Duplicates( 0 ),
		Recode Multiple Response Sort( 0 ),
		Background Color( 117 ),
		Graph Background Color( 2 ),
		Histogram Color( -12241594 ),
		File Location Settings( Installation Directory( "\\C91430\c$\Program Files\SAS\JMP\15" ) )
New Window( "", <<Modal, Text Box( "
   Preferences Set
Kind regards from Berlin
Niklas
Byron_JMP
Re: JMP 15 - Distribution Tool: automatically calculate the tolerance interval on start
You are so close to making this work.
All you have to do is send a message to the platform object to get the TI's to show up.
In the JSL below, there is an example of sending the tolerance intervals to the platform.  This script could easily be pasted on to the end of your distribution script that you save to the data table.
note the variables that are used as handles for the objects
obj=distribution(...    this gives you the thing to reference
obj<<... this sends the message to the object
"obj" is just a variable name, you can make up your own.
dt=Open("$SAMPLE_DATA/Design Experiment/Extraction Data.jmp");
obj=dt<<Distribution(
	Continuous Distribution( Column( :Methanol ) ),
	Continuous Distribution( Column( :Ethanol ) ),
	Continuous Distribution( Column( :Propanol ) ),
	Continuous Distribution( Column( :Butanol ) ),
	Continuous Distribution( Column( :pH ) ),
	Continuous Distribution( Column( :Time ) ),
	Continuous Distribution( Column( :Yield ) )
obj <<
Tolerance Interval(
	Alpha( 0.95 ),
	Proportion( 0.85 )
obj <<
Tolerance Interval(
	Alpha( 0.95 ),
	Proportion( 0.9 ),
	Lower
obj <<
Tolerance Interval(
	Alpha( 0.95 ),
	Proportion( 0.8 ),
	Lower,
	Nonparametric
Byron_JMP
obj <<
Tolerance Interval(
	Alpha( 0.95 ),
	Proportion( 0.85 )
obj <<
Tolerance Interval(
	Alpha( 0.95 ),
	Proportion( 0.9 ),
	Lower
obj <<
Tolerance Interval(
	Alpha( 0.95 ),
	Proportion( 0.8 ),
	Lower,
	Nonparametric
N_Faust-BC
Thx alot for the fast reply and help! :) This works just fine for us.
