Thanks Mark, IMO, this is how it should operate and it's the same as how similar data structures in other languages operate.
How does one test if an associative array has a value assigned to specific key? Since I am assigning specific "Char" (the same as string?) key values to lists, I first tried the Is List function, but it gave me an error. This was my script:
lastTests = Associative Array();
For Each Row (
	partKey = Char(:Name("214:ReadOTP:OTP_Row_40[1]") + 256*:Name("215:ReadOTP:OTP_Row_41[1]") + 256*256*:Name("223:ReadOTP:OTP_Row_49[1]") + 256*256*256*:Name("224:ReadOTP:OTP_Row_4a[1]") + 256*256*256*256*Abs(:Name("123:LOG_SETPOINT_SPEA:SPEA_Setpoint[1]")));
	rowValue = {:Name("start_t"), :Name("part_id"), Row()};
	If (Is List(lastTests[partKey]) ==  1,
		If ( rowValue[1] > lastTests[partKey][1], //if start_t is later
			lastTests[partKey] = rowValue,
		//else if
		(rowValue[1] == lastTests[partKey][1]) & (rowValue[2] > lastTests[partKey][2]), //if start_t is the same but part_id is larger
			lastTests[partKey] = rowValue;
	//else
listOfRowsToSelect = {};
listOfVals = lastTests << Get Values;
For(i = 1, i <= nrows(listOfVals), i++,
	Insert Into(listOfRowsToSelect, listOfVals[i][3]);
dt << Select Rows( listOfRowsToSelect );
And this is the error I see in the log:
subscripted key not in map["192344950106"]{1} in access or evaluation of 'partKey' , partKey/*###*/
In the following script, error marked by /*###*/
For Each Row(
	partKey = Char(
		:Name( "214:ReadOTP:OTP_Row_40[1]" ) + 256 *
		:Name( "215:ReadOTP:OTP_Row_41[1]" ) + 256 * 256 *
		:Name( "223:ReadOTP:OTP_Row_49[1]" ) + 256 * 256 * 256 *
		:Name( "224:ReadOTP:OTP_Row_4a[1]" ) + 256 * 256 * 256 * 256 *
		Abs( :Name( "123:LOG_SETPOINT_SPEA:SPEA_Setpoint[1]" ) )
	rowValue = {:start_t, :part_id, Row()};
	If( Is List( lastTests[partKey/*###*/] ) == 1,
		If(
			rowValue[1] > lastTests[partKey][1], lastTests[partKey] = rowValue,
			rowValue[1] == lastTests[partKey][1] & rowValue[2] > lastTests[partKey][
			2], lastTests[partKey] = rowValue
For( i = 1, i <= N Rows( listOfVals ), i++,
	Insert Into( listOfRowsToSelect, listOfVals[i][3] )
