Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMPĀ® Marketplace
Thierry_S
Is it possible to customize the Add Formula Column menu to include customize functions?
Hi JMP Community,
I want to customize the Add Formula Column menu with a few functions I frequently use. Is this menu modifiable, and if it is, what is the correct method to do so?
Thank you.
Best,
TS
Thierry R. Sornasse
Re: Is it possible to customize the Add Formula Column menu to include customize functions?
I do not see why not after reading the on-line help starting here.
ih
Super User (Alumni) ih
I am blind, it is right there under Custom Transform.  Thanks!
@Thierry_S are you referring to the menu presented when right clicking on a column header? If so I don't know of a way to do that, @Mark_Bailey if it is in that reference I must be blind because I am missing it!
This is the menu I think @Thierry_S refers to:
Example from help:
Add Custom Functions(
	New Custom Function(
		"custom", 	// namespace in which new function resides
		"x1000", 	/* function name. The completely scoped name is
			"custom:x1000".*/
		Function( {x}, x * 1000 ),// function definition
// optional message to enables this as a custom transform
		<<Transform Category( 1 )
Level XII
Besides adding new custom functions ....
Is there a functionality to add existing functions?
e.g.: can I add  "is missing" to the new formula column menu?
The target: via right click menu generate a column
New Column( "missing(name)",	Formula( Is Missing( :name ) ))
up to now I just managed to generate a column
New Column( "my is missing[name]",	Formula( hogi:my is missing( :name ) ))
[same functionality, but less useful]
via
		"hogi",
		"my is missing",
		Function( {col},is missing(col)	),
		<<Transform Category( "hogi" ),
		<<Description( "is missing for the new column formula menu" )
So, with other words, is there are transform category functionality outside of the context of new custom functions?
Level XII
JMP Support:  TS-00152405
Existing functions cannot be added to the menu by name.  You will need to create a custom function that utilizes the existing function as you have already done.
ih
Example from help:
			"custom:x1000".*/
Level XII
When I define a custom function, is  it possible to access the columns that were previously selected by NewFormulaColumn/GroupBy and use them as well as group by entries?
Level XII
Level XII
One one hand, it's very cool that
			"custom:x1000".*/
puts MY OWN formula into jmp and that it really shows up in the Formula editor:
 and not
But actually, I would prefer the latter one.
Next time Jmp is started, the new function will be gone. Same for the computer of my colleague or the computer of the person @ Jmp support.
Is there a way to get a command into the New formula Column right click menu which produces a column with the second formula?
e.g. via an additional argument forAdd Custom Functions( or New Custom Function(
