Tingting
Is it possible to add reference line to only part of the plot in graph builder or control charts?
For instance, if I make a plot with a X group, and I want to put different reference lines for each group/panel only. Is that possible?
Why is this idea important?
In my company, we have a lot of such requests, like we are putting different processes results side by side and they may have different acceptance criteira.
Re: Is it possible to add reference line to only part of the plot in graph builder or control charts?
I think you should repost this to the discussion side instead of wish list. This can be done in few ways in JMP
Jackie_
@jthi Can you share the code?
No specific scripts needed in my example, just have limit columns and use two different plots in graph builder and disable unnecessary variables
Jackie_
@jthi Thanks.
Quick Question - Is it possible to add a reference line (LL and UL) in each group of the plots from the Columns UL and LL in the data table?
