Stephen2020
Interpreting Mixed Model
Hi All,
Several questions regarding linear mixed models.
1) In the "Fit Mixed" personality is there a way to get the prediction expression (Y=Bx+Zu+E), I can get it from other model personalities but can't find it in the "Fit Mixed" personality
2) I am looking at swimming performance in fish, I have two continuous fixed effects and their interaction fit against a continuous response with individual and all its interactions selected as random effects (in total 3 fixed effects:2independent and 1 interaction and 4 random effects)
          2a) when I am interpreting the random variance components is the residual in that table the variance left to be explained by the fixed effects?
          2b) If I am getting significant random variance components and significant fixed effects are my fixed effects significant BECAUSE of the random covariance            or INSPITE of the random covariance?
3) I am working with acceleration which appears to be non-linear and my model fits better when it is log transformed. Am I justified in transforming only acceleration and not my other continuous variables (which appear to be normal or nearly normal) or should I be transforming them all.
Here are a couple of screen grabs
Stephen2020_0-1592308261731.pngStephen2020_0-1592308261731.pngStephen2020_1-1592308312397.pngStephen2020_1-1592308312397.pngStephen2020_2-1592308383498.pngStephen2020_2-1592308383498.png
Thanks in advance
Byron_JMP
Re: Interpreting Mixed Model
1. From the red triangle, Save columns, save prediction formula.
expression is in a new column
2. https://www.jmp.com/support/help/en/15.1/#page/jmp/the-fit-mixed-report.shtml#
I don't see a residuals table in the attached report, however
Marginal Model Inference: Produces plots based on marginal predicted values and marginal residuals. These plots display the variation due to random effects.  https://www.jmp.com/support/help/en/15.1/#page/jmp/marginal-model-inference.shtml#ww1282958
Conditional Model Inference: Produces plots based on conditional predicted values and conditional residuals. These plots display the variation that remains, once random effects are accounted for.
https://www.jmp.com/support/help/en/15.1/#page/jmp/conditional-model-inference.shtml#ww1171576
3. I'm not familiar with fish acceleration. Either a log or some sort of Box-Cox transform seems like it might be reasonable.
