A couple of simple scripts can automate the standardization of all of the chart axes, etc.
Alternatively, the Axis changes can be handled by setting the axis values for one of the axes on one of the charts, and then saving the settings to the column property. Then, you can use Standardize Attributes to copy the Column Properties to all of the columns you want to have the standard values set.
