tsolomon
Community Trekker
Interactive HTML hyperlink doesnt work
I have a script which combines to vlistboxes with button boxes that have hyperlinks in a data table. I save the data table into a report which is an interactive html file. When I save as interactive html, the hyperlinks are disabled. Is there a way to enable them? When I save the data table as regular html, the hyperlinks work but the vlistboxes have different cell sizes and the report looks awful. Is there a way to fix the cell sizes of vlistboxes? I tried putting the vlistboxes in lineup boxes with a fixed size. It looks fine in the journal but once I save to html the formatting is lost.
The code is atttached, any help is greatly appreciated.
Re: Interactive HTML hyperlink doesnt work
After talking with @melaniedrake about JSL, I realised my suggestion wasn't so easy to implement.
With her advice and help from this discussion How-to-generate-buttons-within-a-loop, I figured I should help you out a bit more.
Try the following for your first For loop:
For( i = 1, i < 10, i++, (
	event = Char( :event_number[i]);
	url = (EvalInsert( "http://test.new.com/^event^"));
	button_expr = evalinsert("\[one_button = button box("^event^", web("^url^"), <<underlinestyle)]\");
       eval(parse(button_expr));
  	v << append(one_button);
Interactive HTML can only enable hyperlink buttons with a simple web expression in their script. Your example produces button scripts that look like:
Web("http://test.new.com/" || Char(:event_number[i]));
If your script could produce buttons with simple web links in their button script like:
Web("http://test.new.com/");
They should work when saved as Interactive HTML.
tsolomon
Community Trekker
This works great. I now have active hyperlinks in my intteractive html file. Thanks for the prompt support!!
Cheers,
Tesfu
SKR
SKR
Community Member
I want to open an image, instead of a web page and modified the code from above like this:
For
( i = 1, i < 10, i++, ( event = Char( :event_number[i]); url = (EvalInsert( "http://test.new.com/^event^")); button_expr = evalinsert("\[one_button = button box("^event^", New Window( "Name_xxx", open( img_path, "png")))]\"); eval(parse(button_expr)); v << append(one_button); ) );
This works fine in the jmp report. However, when I create manually an interactive html the links do not work anymore, but give the message: "Disabled script button", when I try to hit the button!
Any suggestions?
