MichaelWelty
Interactive Capability Analysis - Interacitve HTML File
Hello JMP Community,
I’m using the Distribution platform’s Capability Analysis feature and the interactive capability tool/visual that allows running scenarios such as shifting the mean, reducing variation, or changing specification limits to see the impact on process capability.
When I perform this analysis and try to save the interactive visual as an Interactive - HTML file, the file opens but the interactivity does not seem to work. Has anyone else experienced this issue with exporting interactive capability analysis visuals to HTML? Are there any recommended workarounds or settings I might be missing?
Thanks in advance for any insights!
— Michael Welty
Re: Interactive Capability Analysis - Interacitve HTML File
Not all features can be used from interactive HTML and this might be one of those (at least in JMP18). You can check the log and it seems like these will be printed
Interactive HTML: Some lines pan and zoom only partially outside of JMP Live.
Interactive HTML: Controls are not interactive.
