B1234
Importing multiple pdf files in jmp
I have approx. 300 pdf files each containing data tables I want to import to jmp.  I'm trying to loop trough them to open and attach to a new data table but cant even get files to open!
This is what I have tried but doesn't seem to be working.
I'm using JMP 15
path = "C:\example folder\";
theFilesList = Files In Directory(path);
For(i = 1, i <= N Items(theFilesList), i++,
	Open(
		theFilesList[i],
		PDF Tables(
			Table(
				add rows(page(1), Rect(0.3267, 1.2373, 3.5835, 2.5003), column borders(0.3267, 2.7608, 3.5835)),
				add rows(page(1), Rect(0.2685, 3.8856, 8.2878, 5.2504)),
				add rows(page(1), Rect(0.2685, 5.3449, 8.2878, 6.5035))
Re: Importing multiple pdf files in jmp
Try modifying this part of Open
theFilesList[i]
to
path || theFilesList[i]
Error message is telling you that path "\pdf1.pdf" isn't valid path, so add the directory before the file. You might have to remove extra \ from the end of path or start of file name.
theFilesList[i]
to
B1234
This worked like a charm! thank you !!
