- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Importing multiple files
Dear all,
my problem has probably been brought up before as it is quite basic but I couldn't find the solution to my exact problem.
I want to import multiple files with the same structure, manipulate them in the identical way and then glue a subset of them together. I have done the importing and data manipulation part in the following generic way:
dt = Open(
"PATH/File1.xlsx",
Worksheets( "Table1" ),
XXX
// New operation e.g. New column: Column 2
dt << New Column( "Column 2",
Numeric,
"Continuous",
Format( "Best", 12 )
);File1 = dt;File1 << Set Name("File1");
In order to import more files, I would copy the same code to the script and only exchange "File1" by "File2", "File3" and so on. It works but the script length gets quite big since I have a lot of files to import.
I also tried the IMF option. When I chose "Open multiple tables" (I don't want it stacked) I have the data tables already linked to specific names and couldn't get them manipulated with a the generic code described above.
Any ideas for a more elegant solutions?
Thanks a lot!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Importing multiple files
You could try using function() (jmp.com) or expr(). Here are few options using function():
open_and_modify = function({file_path}, {Default Local},
dt = Open(file_path, Worksheets("Table1"), XXX);
dt << New Column("Column 2", Numeric, "Continuous", Format("Best", 12));
dt << Set Name("File1");
return(dt);
dt1 = open_and_modify("PATH/File1.xlsx");
dt2 = open_and_modify("PATH/File2.xlsx");
dt3 = open_and_modify("PATH/File3.xlsx");
//or have a list of paths
file_paths = {"PATH/File1.xlsx", "PATH/File2.xlsx", "PATH/File3.xlsx"};
//create first concatenate before
table_list = {};
For Each({new_file_path}, files,
Insert Into(table_list, open_and_modify(new_file_path));
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Thanks for the quick answer. I tried to implement the code but always get the error message:
"argument should be list in access or evaluation of 'Function'" refering to the line 3
Can you tell me what mistake I made? I always run into this issue.
Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Only thing that quickly comes to my mind is that you are missing {} around the arguments of function
open_and_modify = function(file_path, {Default Local},
return(dt);
when it should be
return(dt);
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Possibly an issue with an international keyboard using the curly braces to make locale-specific characters?
https://stackoverflow.com/questions/2388805/brackets-and-international-keyboards
https://www.reddit.com/r/Anki/comments/j1c5o2/curly_braces_dont_work_with_norwegian_keyboard/
https://cs50.stackexchange.com/questions/9603/curly-brackets-on-my-keyboard
https://discussions.apple.com/thread/7418604
