imendel
Importing kmz files in JMP
Will the kml polygon importer add-in also import kmz files into JMP? I tried to import a kmz file, and it didn't appear to work properly.
Phil_Kay
Re: Importing kmz files in JMP
I suggest that you ask about this in the comments for the thread about the addin.
Also, you might want to see if the XML Import Wizard (JMP 15 onwards) can help. I wrote a JMPer Cable post about this.
Regards,
Phil
imendel
Thank you for your response. I'll see if I can find more information about this.
