KML is an XML-based file format to describe geographic features. The KML Polygon Importer converts polygons found in the KML file into JMP tables which can then be viewed as JMP maps. The KML files must contain polygons. The add-in allows the users to queue multiple KML files to be converted.
Add-in written by intern Shang Ding.
Related blog post: Using the JSL XML parser to import KML map shapes - JMP Blog
Does the kml polygon importer also import kmz files? I tried it, and the cells in the two generated tables were not populated with any values.
