Import data from multiple cells using 'Multiple File import'
Feb 11, 2025 10:05 AM(1922 views)
I am using 'Multiple File import' function to import .CSV to JMP. My data start at raw 253. In .CSV timestamp is in cell C111. How can I modify below script to also import time information?
You could export the data twice, once for data and once for timestamps. Then join them together, just remember to include file names if you are importing multiple files.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '839760' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '839760') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '839760') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
