See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
If & Go to statement
kaushik
I want to write a script such that if a particular condition is true move ahead and if false then move back to a particular label in the script. how to do that. please help.
pmroz
Re: If & Go to statement
JSL does not have a GOTO statement.  You can do what you want with a WHILE loop, CONTINUE and BREAK.
An example of what you want to do would be helpful.
sunilzood
Hi, Please share an example or sample data.
pmroz
robust1972
does it mean the jmp script has to be ran from beginning to end? Not like other language can skip few blocks/lines or go back to certain places prior to if clause?
Jeff_Perkinson
As @pmroz points out there are many Conditional functions that can be used to control the flow of execution of a program.
If you can post an example of the problem you're trying to solve with GOTO perhaps we can show you how to tackle it.
-Jeff
kaushik
This is what i did and it works
a = 0;
tableExpr = Expr(  ) ;
If( a >= 1, //Condition
      Print( "Condition is true." )  //Then
      tableExpr  //Else
If condition is true then proceed else it will execute set of expressions defined earlier in the script.
ram
ram
I guess you dont want to wrap entire jsl code in if or while condition. instead whenever exception occurs it should skip a block. well, since no goto exist in jsl, if you work through function here is a work around. use a dummy for loop and conditional break inside a function.
for(i=1,i<=1,i++,
  bar=12;
  break();
  bar=15;
show(bar);
David_Burnham
source: xkcd.com
-Dave
