agonzales2021
Refreshing items in text edit box, text box, or list box (whichever is easiest)
Ughh the last thing I get held up on is refreshing :\
Okay. So I have the option of having a list box or text edit box (I hate text boxes since you can't hilight text in them) that by default contains only one line "Existing comments go here"
And when a user presses a button below, a function is run that feeds back a list "All_Comments" = {"A", "B"};
I'd like to replace that "Existing comments go here" in the box I use with the items from my list. :) Unfortunately, nothing I am trying is working.
I've tried refreshing, reshowing, appending... maybe I'm not going it right. Here is a simple example I can learn from:
disp = {"INSERT HERE"};
nw1 = New Window("NEW STUFF",
lb= List Box(disp)
All_Comments={"SOAP","FOOD","PUPPIES"};
lb << Append( List box(All_Comments));
ian_jmp
Level X
Re: Refreshing items in text edit box, text box, or list box (whichever is easiest)
Is this it?
NamesDefaultToHere(1);
nw1 = New Window( "NEW STUFF",
		lb = List Box( disp ),
		ButtonBox("Update List", updateScript);
ShowProperties(lb);
updateScript =
Expr(
	All_Comments = {"SOAP", "FOOD", "PUPPIES"};
	lb << removeAll;
	lb << append(All_Comments)
Look in the log to see what other messages 'ListBox()' understands.
pmroz
You can highlight text boxes by changing their background color.
nw = new window("Test",
	tb1 = text box("Hello"),
	tb2 = text box("World")
tb1 << Background Color( "Green" );
tb2 << Background Color( "Light Yellow" );
The method is there for text edit boxes too but doesn't seem to have any effect.
