agonzales2021
Count(Rows Selected) & quickly summarize categories (under one or two columns) of rows selected. [1]
I have two columns selected once a graph launches (those categorical columns are on the X axis). As a user selects different points over the graph, specific rows are selected (like in normal graphing).
I'm looking for a way to do the following things:
1) Count number of rows selected
2) Identify what category (X coordinate) is selected on the graph (since only one will be selected at a time).
I'm amazed at how much difficulty I'm having with such a simple thing. I keep looking at the scripting index but to no avail.
Re: Count(Rows Selected) & quickly summarize categories (under one or two columns) of rows selec
Here is a simple script that shows one way to handle the questions you ask
dt = Open( "$SAMPLE_DATA\big class.jmp" );
dt << bivariate( x( :height ), y( :weight ) );
dt << select rows( {2, 4, 6} );
Show( N Rows( dt << get selected rows ) );
Show( dt:height[(dt << get selected rows)[1]] );
agonzales2021
Always coming to my aid! Thank you so much Jim. This is perfect and exactly what I needed. Reading a little more on this to see what else I can do :D
See Help > Scripting Index > Objects > Data Table > Make Row State Handler
agonzales2021
And thank YOU for this!
Reading about the Row state handler too as I'm pretty sure I can use this in another similar issue I was having :D You guys rock!
agonzales2021
I do have one last followup question though based on the solution you gave me.
In VBA for example there is a function 'countif' where I can specify for a range of cells (N Rows in my case) and count the occurrences of a given item in that column.
I can think of many ways to do this but most of them involve summaries. So say I use that second command you gave me Jim to figure out what element of X is selected. How can I then count the total occurrences of this in the table? (I know that's redundant but like I said there are two x variables and they are linked: months and weeks, so if I select a month, several weeks get selected, etc).
Could I use something like
r = Current Data Table() << get rows where( :height == 60 );
:name[r[Contains( :sex, :sex )]]; followed by the count you suggested?
