Hi @YGerchman ,
In addition to what both @Kevin_Anderson and @Georg have provided, I would add the following:
Another option is if you have additional data that goes along with the power, you can use the model driven multivariate control charts platform (under Analyze > Quality and Process). This platform reduces the multidimensional data (assuming you have other process parameters that are recorded along with the power) using PCA and reports back the T^2 value and by looking at the outliers, you can find out what part of your process was going out of control. This is often helpful in circumstances where there are many process parameters like speed, temp, mixing rate, power, etc. that are all part of the process. Sometimes, it can be that the temp changes, resulting in a larger current draw, thereby changing the power, so depending on the situation, it could be that it's a mixture of factors, and the MDMVCC platform is very helpful for that.
Considering that the failure tends to happen as the batch number goes up, that would suggest something is going on during the process that is changing with time. You can see that right before failure, the power goes up before the crash for both phases, so if you have data from additional processing inputs, this might help to catch a latent factor that is the root cause of failure. Also, there is a big change in power outputs between phase 1 and 2. Did settings change or did the failure from phase 1 impact the power during phase 2?
Bringing in more data might help to determine the cause.
Good luck!,
DS
