JSledz289
IF/Else formula - how to return a blank cell
I am creating an conditional formula. If the condition I am evaluating is false, How do I return a blank cell?
If( :Orientation == "X", :"X Ave"n / 100, ??)
I want to evaluate a column and if it is "X" then I want to perform an equation. If it is any other value I want to return a blank cell.
What do use in the "else" part of the formula to return a blank cell?
Thierry_S
Re: IF/Else formula - how to return a blank cell
If your column type is numeric, you can use the following syntax because the solution provided is geared toward a character type column:
if(:Orientation == "X", :"X ave"n / 100, .)
The empty value is represented by a single period.
Best,
TS
Thierry R. Sornasse
mmarchandTSI
Level V
Since it's a character column, use "".
If( :Orientation == "X", :"X Ave"n / 100, "")
Thierry_S
Best,
TS
Thierry R. Sornasse
JSledz289
Thank You @Thierry_S . The resulting column is numeric therefore " " does not work. Adding the single period worked perfectly.
